[Qgis-user] Limiting File Choices
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Jul 17 15:35:08 PDT 2016
An other option would be to use a file format that uses only a single file. I think spatialite could work. Another option could be to use a csv with WKT. This way, they could also open the text file in a text reader (like notepad) and actually see the content of the file. This way, you could also work more notions of geometry.
I could help you with this. I was a trained elementary teacher in Ontario and Quebec before becoming a archaeological GIS guy!
Cheers!
Nicolas
On Jul 17, 2016 17:58, "berndv. [via OSGeo.org]" <ml-node+s1560n5276786h27 at n6.nabble.com> wrote:
Hi, when you the click "Add vector" button, the file browser will first be defaulted to show all files in the folder. Once you change this in the drop-down at the bottom in "Files of type:" from "All files" to ESRI shapefiles", it will filter to show only .shp. The dialog will remember this setting. Cheers Bernd Am 17.07.2016, 23:02 Uhr, schrieb Michael Jabot < [hidden email] >: I am working with elementary students in using QGIS to develop spatial reasoning.
I have created .shp files for them to use but when they go to the folder to add the .shp, all the supporting files are also present, so we are struggling. Is there a way to set the settings so that only the .shp appears as an option to them?
Thank you in advance for your help and I apologize if this is a silly question
Mike Jabot
-- Bernd Vogelgesang Siedlerstraße 2 91083 Baiersdorf/Igelsdorf Tel: 09133-825374 _______________________________________________
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Limiting-File-Choices-tp5276778p5276786.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Limiting-File-Choices-tp5276778p5276790.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160717/76cbcd5c/attachment.html>
