[Qgis-user] QGIS 2.16 Form View and Field Calculator Buggy?
    Kory Roberts
    kaptainkory at gmail.com
    Sun Jul 24 01:18:04 PDT 2016
I'm running into all kinds of seemingly buggy behaviors with the form
view and field calculator on QGIS 2.16.  Here are some actions and results:
FORM VIEW
1) Start a fresh QGIS project.
2) Create a new point Shapefile layer.
3) Add a new field "test_num" as a decimal number and "text_txt" as text
data.
4) Toggle edit mode and add a point.  Give id as "1", others as NULL.
5) Save layer edits.
6) Open attribute table in table view and enter some text in "text_txt".
7) Switch to form view.
---- BUG 1?: "text_txt" displays NULL instead the text.  Clicking around
and even saving does not seem to refresh the view.  The only thing that
seems to work is to click off of the item in column preview and then
select it again.
8) In form view, open field calculator.
9) Select update existing field and "text_num".
10) Enter a number in the expression space and click OK.
---- BUG 2?: "text_num" displays no change.
FIELD CALCULATOR
11) Add another point to the canvas.
12) Save edits.
13) Open field calculator.
14) Enter "$x" in the expression space and check the output preview.
15) Select the other point.
16) Recheck the value for "$x"...It's the same as before.
---- BUG 3?: This might be me misunderstanding how these variables work,
but I thought $x and $y should change depending on the current feature
selected or being edited?  In an actual work layer with many points, I
keep getting the same values for $x and $y regardless of what I try.
Trying similar actions to bug hunt has resulted in at least 2
freezes/crashes of QGIS along the way, too.
~Kory
