[Qgis-user] Lizmap WMS url work in QGIS desktop but not in other softwares (esri, web browser, online wms renderer)
Daniel Vicente Lühr Sierra (IEE-UACh)
dluhr at ieee.org
Sun Jul 24 14:29:51 PDT 2016
I have been trying to use WMS urls advertised in Lizmap 3 and I have
encountered the following issues:
1) The serverName seems to be fixed at "installation time" in the
index~config.ini.php.conf.php and admin~config.ini.php.conf.php files
under temp/lizmap/www
I have not been able to find a way to update the serverName from the
administration web interface. A reason to do that is that lizmap was
installed and tested in an isolated subnetwork. After being configured
the system was moved to its "real" network (new IP number) and a FQDN.
Shouldn't the advertised wms URL use a hostname/IP detected from the
current url request instead of an internal variable? otherwise, it would
be great if the variable could be modified from the admin interface
instead of "tampering" with above mentioned files.
2) The WMS url works fine from QGIS-desktop, but it doesn't from ESRI
products (arcgis desktop, arcgis online) or directly from the browser or
even from an online WMS renderer. GetCapabilities request works, and
therefore the layers are listed (at least in esri products), also the
legend's urls are properly rendered, but the actual map of a GetMap
request is blank. Is there an extra setup to make the wms compatible
with ESRI? or another workaround?
Thanks
Académico / Academic Staff
Instituto de Electricidad y Electrónica / Institute of Electricity and Electronics
Consejero rama estudiantil IEEE UACh / IEEE UACh Student Branch Counselor
FCI - Universidad Austral de Chile
Tel. +56 (63) 222 1893
e-mail: danielluhr at uach.cl / dluhr at ieee.org
Dirección / Address: General Lagos 2086, Campus Miraflores, Valdivia, Región de los Ríos Chile
