[Qgis-user] Bug in Map Composer?
Neumann, Andreas
a.neumann at carto.net
Mon Jul 25 01:05:11 PDT 2016
Hi Benjamin,
No - you need to submit it at http://hub.qgis.org/ - see also
https://www.qgis.org/en/site/getinvolved/development/bugreporting.html
Thanks for the efforts and greetings,
Andreas
On 2016-07-25 09:36, Fuenfer-Koenigstein.Benjamin at swm.de wrote:
> Hi Andreas,
> I'm using EPSG:31468 (DHDN GK zone 4). The extend in composer is smaller than the extend on project canvas as I use two map boxes in a DIN A4 layout, but the extend which is visible in the composer is fully visible on the project canvas. As the data sources are not public and only available within our company network, I will have to create another test project with public wms and local sources, try to reproduce the issues and send this project and data to your email. Is that all right with you?
> Regards,
> Benjamin Fünfer-Königstein
> S-IP-AN-TG Techn. Geschäftsfelder
> VON: Neumann, Andreas [mailto:a.neumann at carto.net]
> GESENDET: Montag, 25. Juli 2016 09:23
> AN: Fuenfer-Koenigstein.Benjamin S-IP-AN-TG
> CC: qgis-user at lists.osgeo.org
> BETREFF: Re: [Qgis-user] Bug in Map Composer?
> Hi Benjamin,
> What projection are you using? Is the map extent on canvas and composer exactly the same?
> There are projections where scale varies according to the latitude of the extent - but I rather assume it is a bug in QGIS and should be reported in our issue tracker.
> We would need sample data/project and steps to reproduce.
> Thanks,
> Andreas
> On 2016-07-25 08:58, Benni wrote:
>> David, thanks for your answer! The scale in map composer is definitely at
>> 10,000 as I set it in the map-box item properties (numeric scale bar also
>> prints 1:10,000). So the scale in composer is within the threshold of layer
>> visibility. Besides that, as I said, the layer with "scale dependent
>> visibility" set to min 1:10,001 and max 1:9,938 IS visible in map composer
>> but IS NOT in the created pdf. Meanwhile I also found out that with WMS
>> sources displayed in the map, there is a similar issue. The WMS is delivered
>> with different styling at different scale levels. In map composer the style
>> Looks the same as in the project canvas. But in a PDF printed from map
>> composer, the styling looks different (like the one for smaller scales). So
>> all together it still seems to be a bug. Anyone up to test it on your
>> system? I can send the project and files I created for testing.
>> Regards
>> Benjamin
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-in-Map-Composer-tp5277723p5277953.html [1]
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Links:
[1]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160725/14093b61/attachment.html>
