[Qgis-user] Saving/Loading styles in Postgis
Burghardt.Scholle at stadt.wolfsburg.de
Thu Jul 28 22:52:02 PDT 2016
Hi Andreas,
To save the layer styles in a PG table is a cool feature ☺. I have no problems to save the table with a connection based on host/database.
A hint from me: QGIS stores the style-information with the data type “xml”. For me this made problems when exporting / importing this data. By default, the XMLPARSER from postgresql works with the "CONTENT" option. When importing a dump file from the “layer styles”-table you get an error message: “ERROR: invalid XML content”. To prevent this, you need to edit the dump file. Before the insert / copy command to insert the layer styles records you must add the statement “SET xmloption TO DOCUMENT;”.
Regards
Burghardt
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
Gesendet: Donnerstag, 28. Juli 2016 18:14
An: DelazJ
Cc: QGIS User List
Betreff: Re: [Qgis-user] Saving/Loading styles in Postgis
Strange. I can see the empty layer_styles table in my public schema. But saving fails. Maybe it fails because my PG connection is based on a service definition and not on host/database?
On July 28, 2016 6:08:01 PM CEST, DelazJ <delazj at gmail.com<mailto:delazj at gmail.com>> wrote:
Andreas, Styles are indeed saved in the public schema, in a table named "layer_styles". I had never created such a table so I assume it's created by QGIS.
Just made a test and rename my current "layer_styles" table. Then I successfully save a new layer style in PG from QGIS 2.16: a new table "layer_styles" has automatically been created in the public schema.
HTH,
Harrissou
2016-07-28 17:38 GMT+02:00 Neumann, Andreas <a.neumann at carto.net<mailto:a.neumann at carto.net>>:
I have never used the Saving/Loading of styles in Postgis (see http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/vector_properties.html#storing-style-in-a-file-or-a-database)
Do I have to create a special styling table for it to enable this?
Because when I try to save it (QGIS 2.16) I get an error message along the lines that my user may not have permissions to save the style. However, I am trying to save the style with a user that has full administrator rights in Postgis.
In what schema and table are the styles stored? I assume in the public schema. Will QGIS automatically create a styling table or do I have to create one myself?
Thank you for any hints!
Andreas
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160729/adc1f776/attachment.html>
