[Qgis-user] grass-gis plugin in debian jessie
Jürgen E. Fischer jef at norbit.de
Fri Jul 29 12:39:26 PDT 2016
On Fri, 29. Jul 2016 at 12:45:24 -0500, Daniel Torres wrote:
> I'm using QGIS 2.16, and installed GRASS as explained here:
> https://grasswiki.osgeo.org/wiki/Compile_and_Install#GRASS_7_on_Debian_Jessie
The QGIS packages will not use that GRASS - for that you'll also have to manual
build QGIS using the local GRASS.  jessie has GRASS6 and hence the QGIS
packages only use that.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160729/6fb9b248/attachment.sig>
