[Qgis-user] Openstreetmap offline with QGIS
Piotr Kania
p.kania at op.pl
Sat Jul 30 22:56:53 PDT 2016
Hi, I will add that I use QTiles's mbtiles in my android smartphone with
Oruxmaps and it works nicely
W dniu 2016-07-29 o 16:59, Bernd Vogelgesang pisze:
> Hi,
> I normally do it this way to have an offline basemap either for the
> mobile phone or the notebook:
> 1. Install QuickMapServices (an add contributed pack in the settings)
> for a variety of background layer. There are also different flavours
> of OSM, so pick your favourite.
> 2. Install the (tagged as experimental) QTiles plugin.
> Assuming you have to work in certain area at a time only, set your
> canvas to this are.
> In QTiles, you can choose between .zip and .mbtiles (but those mbtiles
> work within QGIS for already a while). Pick mbtiles for file creation.
> Choose your zoom level carefully. If you do not need too much detail,
> 15 will be enough. See http://gis.stackexchange.com/a/7443 for detail
> which zoom level represents which map scale.
> For me this setting resulted in 150MB file for an area of ca. 100
> square kilometers. Higher zoom level or multiple zoom levels will let
> this grow exponentially. You will have to test a bit to find the right
> settings for your purpose.
> The creation of this mbtile will take a while cause it has to download
> all the tiles for the area one after another.
> So better test with a really small area before starting a big download.
> Hope this helps
> Bernd
> Am 28.07.2016, 00:02 Uhr, schrieb <arnaldo.maurizio at gmail.com>:
> Hi everyone,
> I use a laptop on my car where I have installed QGIS to follow the
> position over a map with a GPS. I can calibrate the image taken
> from a 1:25000 detailed topographic map.
> *I need to use QGIS with Openstreetmap offline to follow car GPS
> position.*
> I have downloaded vector tiles formhttp://osm2vectortiles.org
> <http://osm2vectortiles.org/>
> *I am not able to open the MBTiles file with QGIS. Please be
> patient, this is not my work.****I will be grateful if you would
> suggest me how to do this job or if there is a tutorial available.*
> *Are vector tiles from OSM2VECTORTILES right files? Is this the
> right way to work offline?*
> ++running QGIS Desktop 2.16.0 with Windows10
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160731/915d9f60/attachment.html>
