[Qgis-user] New release -2.18 - Polar projection graticules
Nathan Woodrow
madmanwoo at gmail.com
Thu Nov 3 03:40:27 PDT 2016
Hey Lester,
After the release is a bad time to be checking. If a feature is important
to you it's best to get the dev versions early and test before release.
After the release you have to wait for a patch if there ever is one.
- Nathan
On Thu, 3 Nov 2016 8:35 pm Lester Anderson <arctica1963 at gmail.com> wrote:
> Hello,
> Just thought I would see if the new version has improved (fixed) the
> issue with graticules in map composer for Polar projections.
> The latitude lines would be visible straightline segments (very
> obvious) and longitide lines would be missing in places.
> Posted about this issue a while back, so wanted to check and see if
> any changes have been done in this respect (quite important for Polar
> mapping!).
> Thanks
> Lester
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161103/f8f9f52b/attachment.html>
