[Qgis-user] QGis and Mac hardware
Andreas Neumann
a.neumann at carto.net
Mon Nov 7 12:10:24 PST 2016
I would also recommend going with the 15 inch display. The 13 inch
display is on the lower side and probably not a lot of fun. QGIS has
several dialogs and also the styling side panel introduced in 2.16 needs
a bit of a minimum size. If your display is only 13 inch you end up
scrolling a lot in the dialogs and panels.
(Q)GIS needs a bit of a screen size to use it efficiently. Of course, if
you are not on the road you can also connect an external display, which
I also recommend.
I would also upgrade RAM a bit. As others said, the GPU acceleration is
not yet supported.
Andreas
Am 07.11.2016 um 19:18 schrieb Nicolas Cadieux:
> Hi,
> Currently GPU acceleration is not used. Maybe some plugins can use it
> but I have not seen anything yet. I have put in a request to use GPU
> for the qgis 3.0 raster calculator as it needs to be upgraded for huge
> rasters. Currently , the qgis raster calculator can not handle big
> rasters. The new version needs to break up the raster into smaller
> chucks and if you have done that, you might as well use the multi CPU
> ou GPU to do the rest. I an hopping this will be fixed for 3.0.
> Rendering is multithreaded and will be faster the more cores you
> have. Personally, I would go for the quad core without even thinking
> for this and other softwares. I would think of getting an ssd also.
> I have not used qgis on a MAC (PC and ubuntu only) but I expect this
> comment to be valid for Macs also.
> Nicolas
> Le 7 nov. 2016 à 11:12, Matthias Kuhn-2 [via OSGeo.org
> <http://OSGeo.org>] <[hidden email]
> </user/SendEmail.jtp?type=node&node=5294682&i=0>> a écrit :
>> Hi
>> On 11/07/2016 05:02 PM, Square Cube wrote:
>> >> I am looking to update some hardware and am trying to evaluate what
>> >> performance difference in QGis might be gained from the options
>> >> currently on offer from Apple. I have two specific questions:
>> >> - Does QGis have GPU acceleration features that leave the graphics
>> >> card to perform certain calculations, instead of the CPU?
>> No
>> >> - Does QGis take advantage of multiple cores and / or multithreaded
>> >> rendering?
>> Yes, and it is expected that it will make even more use of multiple
>> cores in the upcoming QGIS 3.0 version.
>> Matthias
>> >> I am trying to understand if it would be worth my while investing
>> in a
>> >> 15" MacBookPro (with quad core CPU and discreet graphics card) over a
>> >> 13" MacBook Pro (with dual core CPU and integrated graphics).
>> >> Very grateful for any advice.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > [hidden email] </user/SendEmail.jtp?type=node&node=5294662&i=0>
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email] </user/SendEmail.jtp?type=node&node=5294662&i=1>
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/QGis-and-Mac-hardware-tp5294661p5294662.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> </user/SendEmail.jtp?type=node&node=5294682&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: QGis and Mac hardware
> <http://osgeo-org.1560.x6.nabble.com/QGis-and-Mac-hardware-tp5294661p5294682.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161107/7f4a5054/attachment.html>
