[Qgis-user] Problems on PostGIS disconnect
Árni Geirsson arni at alta.is
Tue Nov 8 03:16:36 PST 2016
Hi
When I connect to PostGIS, the connection gets closed after a while if
there is no activity. The problem is that the connection is not
reestablished successfully. If I try to load a PostGIS layer with DB
Manager after what looks like a reconnect, QGIS complains that the layer is
invalid, even though it loaded successfully when the connection was
properly alive. The only way I have found is to close QGIS and open it
again, reconnect to the database and then everything is fine - meanwhile
nothing has changed in the project or the data. Closing DB Manager and
opening it again makes no difference.
Can anyone shed some light on this?
Arni
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161108/d2c14b70/attachment.html>
