[Qgis-user] Creating parent feature with geometry from child feature
Neumann, Andreas
a.neumann at carto.net
Tue Nov 8 22:26:31 PST 2016
Hi Nicolas,
We have similar issues in our projects.
It looks like a bug to me that the default value is called that many
times.
Matthias: any comments on that? Or can you explain why this happens and
how this can be potentially fixed?
Greetings,
Andreas
On 2016-11-08 17:50, Nicolas Boisteault wrote:
> Logs confirm the issue :
> First time form opened :
> 2016-11-08 17:45:03 CET [15733-1] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-2] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-3] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-4] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-5] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-6] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-7] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-8] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-9] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-10] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:45:03 CET [15733-11] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> Second time form opened :
> 2016-11-08 17:47:10 CET [15733-48] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-49] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-50] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-51] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-52] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-53] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-54] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-55] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-56] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-57] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> 2016-11-08 17:47:10 CET [15733-58] user at carto LOG: statement: SELECT nextval('public.station_gid_seq'::regclass)
> If someone can confirm this issue I'll open a ticket.
> Le 2016-11-08 17:27, Nicolas Boisteault a écrit :
> What is weird is that every time I open the form it increments sequence of 11 NOT 1. So I guess nextval is called 11 times! I'll try to log that. I'm using QGIS 2.18.
> Le 2016-11-08 16:35, Matthias Kuhn a écrit :
> Yes, every time you open a form, a new gid is retrieved (nextval is
> executed) what makes the counter go up very fast.
> Another thing that could need some attention (it might have changed with
> https://github.com/qgis/QGIS/pull/3733 but I didn't check in detail).
> Matthias
> On 11/08/2016 04:19 PM, Nicolas Boisteault wrote: Matthias,
> Thank you for the tip.
> It works without transactional editing.
> I enabled it to test and I like the fact that observation layer is
> automatically put in editable state when I put station layer as
> editable. It is very convenient for users. I'll modify the foreign
> key constraint and will tell if it works for me.
> Now I have an issue which is not related to transactional editing. When
> I create a new station the gid parameter is incremented by +11 not +1.
> Can anyone confirm this issue? Thanks.
> Le 2016-11-08 14:44, Matthias Kuhn a écrit :
> Nicolas,
> Sorry I forgot: you will probably also need to enable transactional
> editing and set the foreign key constraint check to deferred to make it
> work properly.
> Regards
> Matthias
> On 11/08/2016 02:08 PM, Nicolas Boisteault wrote: This is perfect! Thank you very much Matthias.
> Le 2016-11-08 12:45, Matthias Kuhn a écrit :
> Go to the project properties and on the data sources tab check "evaluate
> default values on provider side".
> Regards
> Matthias
> On 11/08/2016 12:37 PM, Nicolas Boisteault wrote: Hi Matthias Kuhn,
> First thank you very much for your help and your work on this feature
> There is room for improvement but this functionality is already great
> as it.
> Another question. I also tried to add a station and an observation from
> the station form.
> When creating, I have 'nextval('public.station_gid_seq'::regclass)' in
> the gid attribute and in the id_station attribute too which is good
> to me.
> Now if i save the observation feature first it won't work because the
> station feature it refers doesn't exist. It is logical to me.
> But if save the new station feature, it only save this feature and not
> the relative observation with the newly foreign created.
> Is it a bug or a limitation? Thanks.
> Le 2016-11-08 12:09, Matthias Kuhn a écrit :
> Hi Nicolas,
> This is a limitation of the current implementation.
> You can either add a new station without geometry first and then
> select
> it in the attribute table and use the add part tool to add a geometry.
> Or add it from its own layer and then link it to the parent
> observation.
> I agree there is room for improvement.
> Regards
> Matthias
> On 11/08/2016 11:49 AM, Nicolas Boisteault wrote:
> Hi List,
> I have two tables :
> * station : gid, geom (point)
> * observation : id, id_station (foreign key)
> There is a 1:N relation; for one station feature there are multiple
> observation features.
> I add the relation between my two tables in QGIS -> project
> properties.
> I use the relation reference widget on id_station and check 'able the
> add of new entities' (not sure about my english translation)
> So now when I create a new observation I can click the plus symbol to
> add a station but I can't see how I can create the point
> geometry. I'm
> not able to click the map.
> Any hint? Thank you all.
> Nicolas BOISTEAULT
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
> <mailto:Qgis-user at lists.osgeo.org>>>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
> <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161109/bcc6631c/attachment.html>
