[Qgis-user] Error when running a simple raster filter
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Thu Nov 10 05:51:37 PST 2016
Not sure why you are getting this specific error.  Just try running it is Saga.  It's already installed with QGIS. Saga is easy to use.
 Is this the first time you have installed QGIS or did you have a previous version installed?
Did you have a 32bit install before?
Nicolas
> Le 10 nov. 2016 à 06:14, Jill Campbell [via OSGeo.org] <ml-node+s1560n5295132h53 at n6.nabble.com> a écrit :
> Hi, I am a new starter on QGIS and would like some instructions to resolve a problem.
> I am following a tutorial (QGIS for Archaeologists - a basic guide) and trying to 'de-trend' a LIDAR map.
> When I run the sequence:
> Processing: toolbox, geoalgorithms, filter tools, simple filter.... run
> I get an error message: 'Can't load requested DLL c:\progr~1\QGIS2~1.18\apps\saga\dll\gdal_MrSID.dll
> I am running QGIS 2.18 Las Palmas which I downloaded from the QGIS website about 3 weeks ago (64-bit version). When I look at my programme files I have the file and pathway 'apps\saga\dll\gdal_MrSID.dll'. I.e the required file seems to be there but not running for this procedure.
> Guidance would be appreciated.
> Jill
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Error-when-running-a-simple-raster-filter-tp5295132.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-when-running-a-simple-raster-filter-tp5295132p5295150.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161110/77070eba/attachment.html>
