[Qgis-user] Rotate Feature changes shape
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Sat Nov 12 07:12:14 PST 2016
Is your file CRS in degrees and your triangle made to 3 points?  If so, make the file in a layer that uses a CRS that uses meter, like a UTM zone 18, then densify the geometry. This will add points along the line  of the triangle.  There is a tool for that. Make sure the project CRS is the same as your file CRS.
Nicolas
> Le 11 nov. 2016 à 20:14, Thomas Stanley-Jones [via OSGeo.org] <ml-node+s1560n5295407h78 at n6.nabble.com> a écrit :
> In QGIS 2.18.0, when I rotate a rectangle, the shape changes.  If it's a
> horizontal rectangle, when it's rotated vertical, the width is cut in
> half and it's twice as long.  When it's rotated to an angle in between
> horizontal or vertical, the shape changes to a parellelogram.  But if I
> rotate it to it's original position, the shape returns to normal.
> Something is wrong with the math in this tool (Rotate Feature(s)).
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Rotate-Feature-changes-shape-tp5295407.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rotate-Feature-changes-shape-tp5295407p5295445.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161112/6e3085de/attachment.html>
