[Qgis-user] MapInfo to QGIS style generator ; error message
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sun Nov 20 09:45:28 PST 2016
I wish I could help.  I don't have that version of Mapinfo.  You could try installing an older version of the program to test.  My hope is that Nathan will help you out.  It would be nice to have that code in the openWOR plugin.
http://www.geoinformations.developpement-durable.gouv.fr/extension-openwor-version-2-6-a1792.html
Nicolas
> Le 18 nov. 2016 à 04:01, dandrigo [via OSGeo.org] <ml-node+s1560n5296422h43 at n6.nabble.com> a écrit :
> Hello,
> For remind, i'm working on Windows 10 64 bits,mapinfo new version Pro 16.0, QGIS 2.16.3.Following  to my previous message, I succeed in resolving my first problem regarding the error message. The Peter 's procedure allows indeed to no longer have an error message during the execution of the command.I remind you the following post (giving the soution) :
> http://gis.stackexchange.com/posts/217934/revisions
>  However, now, when i rerun the same command but the plugin does not still seem to work. No task is done. I let the process run all the night. And the status stays always on
> "Opening Mapinfo ... Exporting style table" .
>  No qml file has been generated. It's strange because i managed to use this plugin in march 2015 last year (with a previous mapinfo version) ... According to you, the reason of the problems could be from updates realised beteween previous version and last new mapinfo v.16?
> Is it possible for someone to try a quick test ? I have already post a message on the Nathan's Blog(plugin 's issues) :
> https://github.com/NathanW2/MapInfo-to-QGIS-style-generator/issues/4
> This plugin is really important for my work.
> actual
> pip freeze | grep win32
> mine is:
> pywin32==218
> but I never used that script
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> On 16 November 2016 at 01:37, dandrigo <[hidden email]> wrote:
> > Good morning,
> > I'm working on windows 10 with mapinfo 16, qgis 2.16.3.
> > I tried to use the usefull following plugin called "MapInfo to QGIS style
> > generator":
> > https://github.com/NathanW2/MapInfo-to-QGIS-style-generator/wiki/Using-MapInfo-to-QGIS-style-generator.
> > But when i launch this following command via osgeo4w shell :
> > python mapinfoToQgis.py F:\temp\commerces.TAB F:\temp\out.qml -c
> > ID_SYMBOLOGIE --UseMapInfo
> > An error message appears. I send you the attachment showing the error
> > message.
> > <http://osgeo-org.1560.x6.nabble.com/file/n5295947/osgeo4w_command_error_mssge.jpg>
> > Could you throw light for me regarding the meaning of the error message and
> > could youhow to help me in order to find a solution?
> > In advance, thank you very much.
> > View this message in context: http://osgeo-org.1560.x6.nabble.com/MapInfo-to-QGIS-style-generator-error-message-tp5295947.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email]
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/MapInfo-to-QGIS-style-generator-error-message-tp5295947p5296422.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapInfo-to-QGIS-style-generator-error-message-tp5295947p5296662.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161120/47eb550a/attachment.html>
