[Qgis-user] Map Composer
RMG reikogoodwin at gmail.com
Mon Nov 21 12:56:35 PST 2016
I am using Nødebo on El Capitan. When I reopen a saved project in which a
map has been composed previously, the map 0 simply refuses to appear,
although when I click on "save the image" it saves the image, but because
it is invisible on the Map composer, editing is difficult. I click on
Update preview, draw map canvas items, set rotate to 0, unlock the layer,
unlock the item, but the map 0 simply won't become visible. The message on
the map area says "Map will be printed here". What is the solution to this
problem?
Thanks for your attention.
Reiko M. Goodwin
facebook.com/GuenonConservationCommunity/
Statement of Confidentiality: The information contained in this electronic
message and any attachments to this message are intended for the exclusive
use of the addressee(s) and may contain confidential or privileged
information. If you are not the intended recipient, please notify
reikogoodwin at gmail and destroy all copies of this message and any
attachments.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161121/46b7c2bd/attachment.html>
