[Qgis-user] How to synchronize GWC configuration
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Mon Nov 21 13:06:30 PST 2016
Hello,
a Geonode 2.4 installation is not showing layers in Geoexplorer anymore.
I´ve recognized that the wms request response with an error saying.
„Could not locate a layer or layer group with id LayerInfoImpl--484e05d9:1460aec6751:-137f within GeoServer configuration
the GWC configuration seems to be out of synch“
Indeed I found a xml file within /usr/share/geoserver/data/gwc-layers/ which refers to a layer which
cannot be found in geonode, geoserver or postgresql.
after that I´ve tried
$ geonode updatelayers --remove-deleted
in hope it will remove leftovers but it failed with:
"'Failed to process coral_reef', AttributeError(\"'NoneType' object has no attribute 'default_style'\",)" <Exception:>
My question is which steps are needed to synchronize GWC configuration again?
Thanks!
Toni
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161121/1883427c/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161121/1883427c/attachment.sig>
