[Qgis-user] Python error on startup
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Nov 22 13:22:54 PST 2016
Next time, I recommend you install Anaconda Python.  It come with a number of scientific packages.  You can indicate during the installation that you do not want to change the environment variables.
Nicolas
> Le 22 nov. 2016 à 16:06, Stephen Ban [via OSGeo.org] <ml-node+s1560n5297018h19 at n6.nabble.com> a écrit :
> Oddly, I was able to fix it by simply reinstalling/upgrading numpy in my existing Python 2.7 install.
> It doesn’t make any sense to me, but it works.
> From: Qgis-user [mailto:[hidden email]] On Behalf Of Nicolas Cadieux
> Sent: November 22, 2016 12:22 PM
> To: [hidden email]
> Subject: Re: [Qgis-user] Python error on startup
> Hi,
> You need to change your default Python to the one that qgis uses.  You can change that in the windows environment variables
> Nicolas
> Le 22 nov. 2016 à 14:38, Stephen Ban [via OSGeo.org] <[hidden email]> a écrit :
> Hi,
> I recently started getting an error message when launching QGIS. I can’t pinpoint exactly when it started happening, but I’m pretty sure it must be related to a recent install of Python when I had both Python 2.7 and 3.5 installed. I also have ArcGIS on my machine, so that was the only Python version installed for awhile. I then installed Python 3.5 to do some testing, but have since uninstalled it so the only remaining standalone Python version is ArcGIS’s 2.7. I’ve purged any extraneous Python environment variables and cleaned the Windows registry to no effect. I’m running Windows 10 64-bit edition, and have always installed the 64-bit versions of QGIS.
> I was originally running GQIS 2.16.1, then uninstalled it and installed QGIS 2.18. Both versions give me the same error message on startup: “Python error: Couldn’t load plugin ‘processing’ See message log (Python Error) for more details.” The Python message log contains the following:
> “1 Traceback (most recent call last):
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 308, in loadPlugin
> __import__(packageName)
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 607, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\__init__.py", line 29, in <module>
> from processing.tools.general import * # NOQA
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\general.py", line 31, in <module>
> from processing.core.Processing import Processing
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\core\Processing.py", line 55, in <module>
> from processing.algs.qgis.QGISAlgorithmProvider import QGISAlgorithmProvider
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\QGISAlgorithmProvider.py", line 109, in <module>
> from .RasterLayerStatistics import RasterLayerStatistics
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\RasterLayerStatistics.py", line 36, in <module>
> from processing.tools import raster
> File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\raster.py", line 29, in <module>
> import numpy
> File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\__init__.py", line 180, in <module>
> from . import add_newdocs
> File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\add_newdocs.py", line 13, in <module>
> from numpy.lib import add_newdoc
> File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\__init__.py", line 8, in <module>
> from .type_check import *
> File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\type_check.py", line 11, in <module>
> import numpy.core.numeric as _nx
> File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\core\__init__.py", line 14, in <module>
> from . import multiarray
> ImportError: DLL load failed: %1 is not a valid Win32 application.”
> Any help or advice on resolving this error would be appreciated.
> Stephen
> Stephen Ban, Ph.D., RPBio.
> National Ocean Spatial Analysis Manager
> Canadian Parks and Wilderness Society
> #410-698 Seymour Street, Vancouver, B.C. V6B 3K6
> Tel: 604 685-7445 ext. 30
> Fax: 604 629-8532
> Email: [hidden email]
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Python-error-on-startup-tp5297007.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> View this message in context: Re: Python error on startup
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> [hidden email]
> http://osgeo-org.1560.x6.nabble.com/Python-error-on-startup-tp5297007p5297018.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Python-error-on-startup-tp5297007p5297024.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161122/00d97c13/attachment.html>
