[Qgis-user] QGIS MBTiles
Stefan Löhr
loehr at topographics.de
Wed Nov 23 06:56:10 PST 2016
Thanks for your test!
I was on QGis 2.14.1.
After an update to QGis 2.14.8 it works.
Thanks QGIS Team!!!!! You are really great!
But one little thing to mention:
QGIS 2.14.1 installs by default to "C:\Program Files\QGIS Essen"
QGIS 2.14.8 installs by default to "C:\Program Files\QGIS 2.14"
That should be a little more consistent, because you end up with two
installed versions on disk when you really only want to update.
But of course that is complaining on a high comfort level ;-)
Thanks for your help!
Stefan
Am 23.11.2016 um 14:46 schrieb Even Rouault:
> > No, the error message you got shouldn't normally come up if minzoom and
> > maxzoom are available. Can you share your dataset (possibly
> privately) so I
> > can investigate?
> With the file privately sent by Stefan, both gdalinfo and QGIS work
> fine for me. Do you use the latest QGIS 2.14.X point release that ship
> with a recent GDAL ? There might have been fixes in the MBTiles driver.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161123/847afcde/attachment.html>
