[Qgis-user] 2.18.0: Dissolve doesn't allow multiple fields
Nyall Dawson nyall.dawson at gmail.com
Thu Nov 24 15:02:54 PST 2016
On 25 November 2016 at 07:36,  <mvr at posteo.de> wrote:
> Hi all,
> the changelog for 2.18 says that the processing dissolve algorithm now
> allows multiple unique fields
> (http://qgis.org/de/site/forusers/visualchangelog218/index.html#feature-processing-dissolve-algorithm-accepts-multiple-fields).
> I just downloaded and installed the 2.18 version and removed the old
> versions, but the dissolve tool looks the same as before - only one unique
> ID field can be chosen. Are there some files from the older QGIS-versions
> which haven't been removed and now the new tool can't load? Or what else can
> cause this problem?
> Thanks for help!
Check your .qgis2\python\plugins folder. If there's a "processing"
folder there it should be deleted.
Nyall
> Martin
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
