[Qgis-user] Max size for a page print
Andrea Peri
aperi2007 at gmail.com
Mon Nov 28 00:14:32 PST 2016
I found how set the page size for export.
I was using (wrongly) the setting: composer -> page setup
Instead the right setting was in the tabs sections: Composition > Page
Size -> Presets.
Sorry for noise,
Regards.
Andrea.
2016-11-28 8:43 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I notice in qgis composer is not possible to set a page size greater
> than the max size of the printer installed drivers.
> I guess this is a right choice when the output is directly to the
> printer. But when the output is a PDF file or a Image file the limit
> seem unuseful.
> With the actual setting of QGIS to produce some PDF with large format
> on a windows machine is need to install a driver for a large format
> printer.
> Unfortunatelly often this drivers refuse to install if there isn't
> really the printer.
> Any help is welcome.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
