[Qgis-user] suddenly unable to open shape files
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Mon Nov 28 03:30:02 PST 2016
Hi Andreas
The harddisk was not full; about of 200 GB free space. If the whole
system was healthy before I cannot say for sure. Everything used to work
until suddenly I had problems with shapes and Grass files. Anyway, now
it works again.
Thanks for your suggestions,
Mira
On 28/11/16 11:26, Neumann, Andreas wrote:
> Hi Mira,
> It is highly unlikely that any data can corrupt/modify QGIS as a
> software. It could crash it, but it can't modify binaries/libraries of
> QGIS.
> Not knowing about your situation - are you sure that your whole system
> was in a healthy state? Perhaps one harddisk or partition was full?
> That could explain such a behaviour.
> Andreas
> On 2016-11-28 10:10, Mira Kattwinkel wrote:
>> Dear all,
>> maybe that's of interest for someone else: I solved the problem by
>> completely removing QGIS and all its configuration files (using
>> 'synaptic' on Linux and some manually) and reinstalling it.
>> I guess the problem emerged from a very large Grass mapset (about
>> 2000 raster and vector files). Could it be that this messed up
>> something internally that it even affected shape files outside of
>> this folder?
>> Cheers,
>> Mira
>> On 25/11/16 18:17, Nicolas Cadieux wrote:
>>> Zip me the file if it's not confidential. I can test it.
>>> Le 25 nov. 2016 à 12:07, Mira Kattwinkel [via OSGeo.org
>>> <http://OSGeo.org>] <[hidden email]
>>> </user/SendEmail.jtp?type=node&node=5297452&i=0>> a écrit :
>>>> Hello Nicola
>>>> Thanks for the suggestion but this is not the problem. I did not move
>>>> any files and it happens with whatever shape file I try.
>>>> Mira
>>>> On 25/11/16 17:58, Nicolas Cadieux wrote:
>>>>> Hi,
>>>>> Perhaps you moved or copied the shape files and forgot to move the
>>>>> accompanied files (3 to 8 files with different extensions like .shx
>>>>> .dbf .shp .prj)? If you just move the .shp and not the others, this
>>>>> is will create errors. The .shx contains the geometries. You may get
>>>>> this kind of message if you try to drag and drop the .shx and not the
>>>>> .shp in QGiS.
>>>>> .tiff will not crash because it's a lone file.
>>>>> Nicolas
>>>>> Le 25 nov. 2016 à 11:36, Mira Kattwinkel [via OSGeo.org
>>>>> <http://OSGeo.org>
>>>>> </user/SendEmail.jtp?type=node&node=5297448&i=0>> a écrit :
>>>>>> Dear list
>>>>>> I have been working with QGIS 2.14 and now 2.18 for a while on Linux
>>>>>> Mint 17. Suddenly, I cannot open shape files any more. When trying to
>>>>>> load them I get the message: "Layer is not valid: The layer XX.shp is
>>>>>> not a valid layer and can not be added to the map." In the log
>>>>>> message
>>>>>> panel under ogr it says: "Data source is invalid (Unable to open
>>>>>> XX.shx
>>>>>> or XX.SHX.Try --config SHAPE_RESTORE_SHX true to restore or
>>>>>> create it)"
>>>>>> Additionally, I cannot open GRASS files any more (which also used to
>>>>>> work fine) and get the error:" Error reading database file from:
>>>>>> /usr/share/qgis/resources/srs.db Because of this the projection
>>>>>> selector
>>>>>> will not work..." and then QGIS crashes.
>>>>>> Interestingly, I can open shape files from my file browser (it starts
>>>>>> QGIS and loads the file) but then I cannot add another one. Raster
>>>>>> (GeoTif) data are also fine.
>>>>>> I have no idea what's causing this. I have tried removing and
>>>>>> reinstalling QGIS (version 2.18 and 2.14) without any success.
>>>>>> Can anybody give me any hint what might have corrupted my system?
>>>>>> Thanks a lot,
>>>>>> Mira
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> [hidden email] </user/SendEmail.jtp?type=node&node=5297446&i=0>
>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> If you reply to this email, your message will be added to the
>>>>>> discussion below:
>>>>>> http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446.html
>>>>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>>>>> </user/SendEmail.jtp?type=node&node=5297448&i=1>
>>>>>> To unsubscribe from Quantum GIS - User, click here.
>>>>>> NAML
>>>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>>> View this message in context: Re: suddenly unable to open shape files
>>>>> <http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297448.html>
>>>>> > Sent from the Quantum GIS - User mailing list archive
>>>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>>>>> at Nabble.com <http://Nabble.com>.
>>>>> [hidden email] </user/SendEmail.jtp?type=node&node=5297449&i=0>
>>>> -- Dr. Mira Kattwinkel
>>>> Quantitative Landscape Ecology
>>>> Institute for Environmental Sciences
>>>> University of Koblenz-Landau
>>>> Fortstraße 7
>>>> 76829 Landau
>>>> Germany
>>>> Phone: + 49 6341 280-31553
>>>> Office: Building I, Room 2.02
>>>> [hidden email] </user/SendEmail.jtp?type=node&node=5297449&i=1>
>>>> discussion below:
>>>> http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297449.html
>>>> </user/SendEmail.jtp?type=node&node=5297452&i=1>
>>>> NAML
>>> files
>>> <http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297452.html>
>>> at Nabble.com.
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> Dr. Mira Kattwinkel
>> Fortstraße 7
>> 76829 Landau
>> Germany
