[Qgis-user] WFS layer list not updated?
Ari Jolma
ari.jolma at gmail.com
Sat Oct 1 05:44:07 PDT 2016
01.10.2016, 14:51, Even Rouault kirjoitti:
> Hi Ari,
>> I'm using 2.16.2 and when I connect to a WFS provider the layer list is
>> not updated after the first time I press Connect in the dialog. This
>> means that when I publish or unpublish layers at the server those
>> changes are not shown in the client.
>> I can force the update by removing the client cache (rm -rf
>> .qgis2/cache/data7).
>> I can fix the problem by changing 'false' to 'true' in the sendGet call
>> in QgsWFSCapabilities::requestCapabilities (that is the bool
>> forceRefresh parameter). However, changing code seems rather drastic, so
>> what am I doing wrong?
> This is probably a shortcoming of my recent refactoring in the WFS provider
> where I borrowed some things from the WMS provider. Instead of full caching as
> currently done vs no caching as before, perhaps there could be a medium way:
> if capabilities are needed due to pushing the Connect button, then we should
> re-issue a network request. In other cases, we could use the cached version.
> Actually looking at the code, I think this is what the WMS provider does.
> Could you file a ticket about that (if there isn't already one) ?
Added as #15647.
It seems to me that user pushing the button should force a network request.
Thanks,
Ari
> Even
