[Qgis-user] Struggling with datum transformations and grid shift files
Neumann, Andreas
a.neumann at carto.net
Tue Oct 4 03:58:14 PDT 2016
I am struggling in QGIS 2x with datum transformations.
The manual is not explicit how to handle this correctly.
Here are the steps I tried:
1. As far as I understand, I have to copy the gsb file to the directory
where proj stores the gsb files, in my case "C:\Program
Files\OSGeo4W64\share\proj". Alternatively, one could set another folder
and adjust the PROJ_LIB env variable accordingly.
2. In "Settings" --> "Options" --> "CRS" I can define default datum
transformations. I tried to enter 21781 (Source CRS), 2056 (Destination
CRS), +nadgrids=CHENYX06a.gsb (Source datum transfomation). Destionation
datum has been left empty.
3. I would expect that whenever this combination 21781 --> 2056 shows up
that QGIS would ask me to pick one the defaults specified in 2.
The problem is that 2. does not work. When I close the dialogue and
reopen it, my modifications are gone ... and I never have the chance to
select my datum transformation option.
Can you help me what I am doing things wrong?
Thank you,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161004/024513a2/attachment.html>
