[Qgis-user] is there a way to install a running well version of QGis in Xenial 16.04??
    Tomas Lanczos
    tlanczos at gmail.com
    Tue Oct  4 08:59:19 PDT 2016
Hello, I have also problems with qgis 2.14, as well as the 2.16 versions,
esp (ubuntu xenial) ecially with the grass plugin. In 2.16 I opened a
mapset once, but next time I get the message that the .gislock is there,
the same for all the other mapsets, even the .gislock was not physically
there. When I downgraded to 2.14. it can't open the grass plugin at all.
I am using the ubuntugis repositories, they are present also
/etc/apt/sources.list.d.
Regards
Tomas
On Wed, Sep 21, 2016 at 2:07 AM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> Henri - sorry for the late reply back.
> If you look under /etc/apt/sources.list.d - do you have a QGIS.list file?
> Or something under /etc/apt/sources.list with a repository listing for
> QGIS?
> Yes - it is possible because I am sitting here running QGIS on Ubuntu
> 16.04.
> Randy
> On 09/19/2016 02:36 PM, Henri LABORDE wrote:
> Yes, seriously,  is there a way???
> which QGis version ?
> and how to proceed?
> That sems impossible, because a lot of  mysterious messages like these
> ones:
> cheers
> Henri (desperate Linux user)
> Paramétrage de qgis-providers (2.14.1+dfsg-3~xenial0) ...
> /usr/lib/qgis/crssync: error while loading shared libraries: *libgif.so.4*:
> cannot open shared object file: No such file or directory
> dpkg: erreur de traitement du paquet qgis-providers (--configure) :
>  le sous-processus script post-installation installé a retourné une erreur
> de sortie d'état 127
> Paramétrage de libjs-leaflet (0.7.3~dfsg-1) ...
> Paramétrage de qgis-common (2.14.1+dfsg-3~xenial0) ...
> dpkg: des problèmes de dépendances empêchent la configuration de qgis :
>  qgis dépend de qgis-providers (= 2.14.1+dfsg-3~xenial0) ; cependant :
>  Le paquet qgis-providers n'est pas encore configuré.
> dpkg: erreur de traitement du paquet qgis (--configure) :
>  problèmes de dépendances - laissé non configuré
> Paramétrage de qgis-plugin-globe-common (2.14.1+dfsg-3~xenial0) ...
> Aucun rapport « apport » n'a été créé car le message d'erreur indique une
> erreur consécutive à un échec précédent.
> de qgis-plugin-globe :
>  qgis-plugin-globe dépend de qgis (= 2.14.1+dfsg-3~xenial0) ; cependant :
>  Le paquet qgis n'est pas encore configuré.
> dpkg: erreur de traitement du paquet qgis-plugin-globe (--configure) :
>              Paramétrage de qgis-plugin-grass-common
> qgis-provider-grass :
>  qgis-provider-grass dépend de qgis (= 2.14.1+dfsg-3~xenial0) ; cependant :
> dpkg: erreur de traitement du paquet qgis-provider-grass (--configure) :
> Aucun rapport « apport » écrit car MaxReports a déjà été atteint
>        dpkg: des
> problèmes de dépendances empêchent la configuration de qgis-plugin-grass :
>  qgis-plugin-grass dépend de qgis (= 2.14.1+dfsg-3~xenial0) ; cependant :
>  qgis-plugin-grass dépend de qgis-provider-grass (=
>  Le paquet qgis-provider-grass n'est pas encore configuré.
> dpkg: erreur de traitement du paquet qgis-plugin-grass (--configure) :
> Traitement des actions différées (« triggers ») pour libc-bin
> (2.23-0ubuntu3) ...
> Des erreurs ont été rencontrées pendant l'exécution :
>  qgis-providers
>  qgis
>  qgis-plugin-globe
>  qgis-provider-grass
>  qgis-plugin-grass
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> very very bad trip since I've made the upgrade from 14.04 LTS to 16.04 LTS
> La curiosité est un vilain défaut...curiosity is a bad thing...
> > Message du 14/09/16 06:24
> > De : "Blumentrath, Stefan" <Stefan.Blumentrath at nina.no>
> > A : "Randal Hale" <rjhale at northrivergeographic.com>
> <rjhale at northrivergeographic.com>, "qgis-user at lists.osgeo.org"
> <qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org>
> > Copie à :
> > Objet : Re: [Qgis-user] Ubuntu updating instructions
> And if I may add:
> Even if the users are aware of the fact that ubuntugis-unstable contains
> the current releases, it can be hard to impossible to convince a
> GIS-ignorant system administrator that it is OK to install “unstable”
> packages.
> But this issue is not a QGIS issue I guess...
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Randal Hale
> > *Sent:* 13. september 2016 16:45
> > *To:* qgis-user at lists.osgeo.org
> > *Subject:* Re: [Qgis-user] Ubuntu updating instructions
> On 09/13/2016 10:23 AM, Jürgen E. Fischer wrote:
> Hi Randal,
> On Tue, 13. Sep 2016 at 00:21:21 -0400, Randal Hale wrote:
> It's a little bit confusing. There are like three repositories:
> stable, unstable, and testing. Testing you don't want (unless you
> want to test packages). Typically stable is a bit older. Unstable is
> current. Which doesn't really make sense - but that's the way it is.
> Not like it matters much in this case.
> We have packages in qgis.org/debian/ against the plain versions of the
> distributions (debian and **ubuntu**) and in qgis/ubuntugis/ packages against
> newer dependencies from - and only from - ubuntugis-unstable.
> Looks like it's hard for people to accept that there are also ubuntu packages
> in a directory called debian and that probably makes them jump on the other
> because it has ubuntu in it's name.
> I was thinking about it last night (and I was up way to late) and it is a
> bit confusing for the casual user. They've installed Ubuntu (or
> mint/debian/xubuntu/etc) and they may not understand ubuntu is based off
> debian. So like you said - they see debian but want to use Ubuntu. They go
> to UbuntuGIS and they see the repositories for UbuntuGIS and the choice is
> unstable (and no one likes unstable software) and stable (which doesn't
> contain the newest software). So you end up going "Use Unstable because
> it's stable and current".
> Under my /etc/apt/sources.list.d directory I made a qgis.list file
> and put the following in there:
> deb http://qgis.org/debian xenial main
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu xenial main
> Why?  That are the packages not based on ubuntugis with the dependencies from
> ubuntugis.
> Do I have this wrong? I thought I had the repositories for the install
> correct based off the directions on qgis.org. Which I could completely
> have it wrong. With the above repos I'm getting QGIS 2.16.x and GDAL 2.1.x.
> Jürgen
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale
> Randal Hale
> North River Geographic Systems, Inchttp://www.northrivergeographic.com
> twitter:rjhale     http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gishttps://www.facebook.com/NRGSInc
Water, taken in moderation cannot hurt anybody.
        -- Mark Twain
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161004/2bb2ff16/attachment.html>
