[Qgis-user] Question on @cluster_color and expression
Andreas Neumann
a.neumann at carto.net
Thu Oct 6 23:40:15 PDT 2016
Hi all, Hi Nyall,
I am testing the new cluster renderer in QGIS master.
I want to test if all points in a cluster are of the same color (class),
if not, specify an alternative color for clusters with mixed colors.
I am using the expression:
CASE WHEN @cluster_color IS NULL THEN '255,50,0' ELSE @cluster_color END
However, for some reason the "IS NULL" test is failing - the ELSE part
works.
I get black colors as fall-back, but I wanted to have '255,50,0' as the
fallback color.
Anyone knows why my expression fails?
Thanks,
Andreas
