[Qgis-user] Python3 support of qgis...
Nyall Dawson nyall.dawson at gmail.com
Fri Oct 7 16:09:13 PDT 2016
On 8 Oct 2016 8:43 AM, "JIA Pei" <jp4work at gmail.com> wrote:
> Hi, all:
> I tried to convert all python files from being compatible with python2 to
being compatible with python3, with "2to3", but it still has a lot of the
error messages as follows:
>> RefactoringTool: Warnings/messages while refactoring:
>> RefactoringTool: ### In file
./python/ext-libs/future/future/backports/email/charset.py ###
>> RefactoringTool: Line 5: Calls to builtin next() possibly shadowed by
global binding
./python/ext-libs/future/future/builtins/misc.py ###
>> RefactoringTool: Line 104: Calls to builtin next() possibly shadowed by
global binding
./python/ext-libs/future/future/moves/urllib/request.py ###
>> RefactoringTool: Line 38: could not convert: from urllib import *
>> RefactoringTool: Cannot handle star imports.
>> RefactoringTool: Line 39: could not convert: from urllib2 import *
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/compiler.py ###
>> RefactoringTool: Line 19: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/ext.py ###
>> RefactoringTool: Line 23: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/filters.py ###
>> RefactoringTool: Line 21: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/lexer.py ###
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/nodes.py ###
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/parser.py ###
>> RefactoringTool: Line 14: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/runtime.py ###
>> RefactoringTool: Line 17: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/testsuite/api.py
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/testsuite/ext.py
>> RefactoringTool: Line 20: Calls to builtin next() possibly shadowed by
global binding
./python/ext-libs/jinja2/testsuite/lexnparse.py ###
global binding
>> RefactoringTool: ### In file ./python/ext-libs/jinja2/_compat.py ###
>> RefactoringTool: Line 86: Calls to builtin next() possibly shadowed by
global binding
./python/ext-libs/requests/packages/urllib3/packages/six.py ###
>> RefactoringTool: Line 232: Calls to builtin next() possibly shadowed by
global binding
>> RefactoringTool: ### In file ./python/ext-libs/six.py ###
>> RefactoringTool: Line 525: Calls to builtin next() possibly shadowed by
global binding
./python/plugins/db_manager/dlg_sql_layer_window.py ###
>> RefactoringTool: Line 25: Calls to builtin next() possibly shadowed by
global binding
./python/plugins/db_manager/dlg_sql_window.py ###
global binding
./tests/src/python/test_provider_postgres.py ###
>> RefactoringTool: Line 9: Calls to builtin next() possibly shadowed by
global binding
./tests/src/python/test_qgsvectorfilewriter.py ###
global binding
>> RefactoringTool: There were 4 errors:
>> RefactoringTool: Can't parse
./python/ext-libs/future/future/backports/http/client.py: ParseError: bad
input: type=22, value=u'=', context=('', (395, 41))
./python/ext-libs/future/future/backports/test/support.py: ParseError: bad
input: type=22, value=u'=', context=('', (909, 41))
>> RefactoringTool: Can't parse ./scripts/parse_dash_results.py:
ParseError: bad input: type=1, value=u'exec', context=('', (354, 6))
>> RefactoringTool: Can't parse ./tests/src/python/qgis_wrapped_server.py:
ParseError: bad input: type=22, value=u'=', context=('', (105, 55))
> Is there a plan to convert qgis to be fully compatible with python3???
Qgis 3.0, due early next year, will be python 3.0/qt5 exclusive.
If you're keen, you can grab the current master source and build a python 3
compatible version from that. There's also daily master builds available
for debian/Ubuntu ( not windows yet).
Nyall
> Pei JIA, Ph.D.
> Email: jp4work at gmail.com
> cell in Canada:    +1 778-863-5816
> cell in China: +86 186-8244-3503
> Welcome to Vision Open
> http://www.visionopen.com
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161008/8afc2b3e/attachment.html>
