[Qgis-user] inconsistenty when calculating area depending on file type or projection?
    DelazJ
    delazj at gmail.com
    Wed Oct 12 05:40:01 PDT 2016
To complete Nicolas answer, you should check what are the measurements
options set in Project --> Project Properties --> General tab.
See also
http://docs.qgis.org/2.14/en/docs/user_manual/introduction/general_tools.html#measuring
2016-10-12 14:07 GMT+02:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> You may be calculating square degrees and not metres.  It can depend on
> the crs depending on the tools you are using.
> Nicolas
> Le 11 oct. 2016 à 08:54, Martina Schäfer [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290417&i=0>> a écrit :
> I experienced some confusion with calculation of area using the field
> calculator in QGIS version 2.16.3. Since I'm using MapInfo Professional as
> well, I mainly use tab-files that I can open in both programmes, but
> occasionally I save as shapefile since this used to be the default in QGIS.
> When comparing files, I coincidently realized that there was a mismatch in
> calculated area for the shapefile and the tab-file for exactly the same
> polygons! I used the field calculator in the attribute table in both cases,
> but for the shapefile the resulting areas were almost doubled in area
> compared to the tab-file. Any idea why this is happening?
> I also realized similar differences when calculating area in a file where
> projection has been converted from SWEREF99TM (a Swedish national
> projection) to WGS84. There differences occurred in both the tab and
> shapefile compared to the area calculated for the same tab-file in MapInfo.
> Again I find this very confusing!
> I need to rely on the area-calculations thus I really hope someone here
> can explain to me what is happening!
> Thanks in advance,
> Martina
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/inconsistenty-when-
> calculating-area-depending-on-file-type-or-projection-tp5290228.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290417&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: inconsistenty when calculating area
> <http://osgeo-org.1560.x6.nabble.com/inconsistenty-when-calculating-area-depending-on-file-type-or-projection-tp5290228p5290417.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161012/33740359/attachment.html>
