[Qgis-user] Append in Import Vector into PostGIS didn't
Sandro Santilli
strk at kbt.io
Mon Oct 17 02:07:15 PDT 2016
Frederico, would you be up to turn this into a pull request ?
There's now a test for connection string building in
python/plugins/processing/tests/GdalAlgorithmsTest.py
where you could add a test for it.
--strk;
On Sat, Oct 15, 2016 at 08:29:57PM -0300, Frederico dos Santos Soares wrote:
> --Sorted out
> Sharing with the list the solution found.
> In a current work process, I need to run several models using the
> "processing" as "[OGR] Import into PostGIS" is the only tool that allows
> the output of the models do "append" on a table of Postgres / PostGIS, I
> had to solve the problem in the script.
> Recalling I am using QGIS 2.8
> The reference that I used to solve the problem, comes from the same tool in
> version 2.14. Clarify that in version 2.14 Import into postgis did not work
> if executed within a model, at least not work for me, I believe we have
> another bug there.
> Returning. The "Import into postgis" (for available connections) works in
> ogr2ogrtopostgislist.py file in the ... \ QGIS Wien \ apps \ qgis-ltr \
> python \ plugins \ processing \ algs \ gdal
> The file in its original version builds the command of ogr2ogr with the
> schema parameter "-lco" + schema outside the database configuration
> parameters: -> ... -append -nlt MULTILINESTRING -lco SCHEMA = teste_geo ...
> I changed the file so that the schema parameter was written into the
> connection as follows "active_schema =" + schema -> PG: "host = localhost
> port = 5432 dbname = gis password = xxx active_schema=temp
> And voila it worked!
> Attached the file, marked with # rows that were changed.
> I hope that helps someone want to use this tool in their models. I'm using
> it's pretty cool.
> Best regards.
> Geógrafo
> 55 61 8416 0105
> fssunb at gmail.com
