[Qgis-user] Using aggregates functions to count intersected features from another layer
Matthias Kuhn
matthias at opengis.ch
Wed Oct 19 12:53:17 PDT 2016
The Expressions Plus plugin is there for sharing expressions that are of
broader interest but for whatever reason did not make it (yet) to core [1]
Would be great to push there whatever is interesting so we don't have to
install a bazillion different plugins.
Matthias
[1] https://plugins.qgis.org/plugins/qgsexpressionsplus/
On 19/10/16 21:42, DelazJ wrote:
> Hi all,
> Thank you all for your answers. This is really a great community! I
> already knew that but let me say it loudly. It also shows all the
> capabilities of QGIS to solve a problem.
> Nicolas, as Andreas said, I'm looking for something dynamic, live.
> The virtual layer can indeed be an option despite the creation of an
> intermediate but somehow live layer. Would be nice to have Andreas
> questions documented in the user manual so that users are fully aware
> of any potential limitations of the feature or its great power.
> Another powerful feature I often neglect is the function editor. Maybe
> because there are so many functions in the list that I end up thinking
> that their combination would be enough. I think it's the way I will go
> as no intermediate layer is involved and despite your remarks (which
> are not far from Andreas questions about virtual layers). Thank you
> Germán for reminding me.
> That makes me wonder: we have in QGIS, ways to share processing
> scripts and models, to share symbols, styles... What about something
> to share custom expression functions? Plugins somehow already do that
> but I think there are many people that have an operational code (that
> fills some small and common needs like mine) but don't have
> time/skills to create the Gui around. Does it sound
> reasonable/feasible? Maybe should I open a discussion in dev list (or
> a ticket)?
> Back to the approach I was following to solve the issue (combining
> default functions in expression) may I understand that it was endless?
> No way to group by when using aggregate function...?
> Greetings,
> Harrissou
> Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Germán Carrillo" <carrillo.german at gmail.com
> <mailto:carrillo.german at gmail.com>>
> Pour : "Neumann, Andreas" <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>, "Harrissou 'DelazJ'" <delazj at gmail.com
> <mailto:delazj at gmail.com>>
> Cc : "Nathan Woodrow" <madmanwoo at gmail.com
> <mailto:madmanwoo at gmail.com>>, "qgis-user" <qgis-user at lists.osgeo.org
> <mailto:qgis-user at lists.osgeo.org>>, "Nicolas Cadieux"
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>
> Objet : [Qgis-user] Using aggregates functions to count intersected
> Date : mer., oct. 19, 2016 18:04
> Hi All,
> Harrissou, have a look at [1] for a very similar question and one
> possible solution using the Function Editor (of course, instead of sum
> you would use count).
> Do you other devs find that approach useful? Any hint for keeping the
> index up-to-date?
> Is there any interest in having this kind of functions available for
> QGIS expressions? I could help with that.
> Regards,
> Germán
> [1] http://gis.stackexchange.com/a/212762/4972
> <http://gis.stackexchange.com/a/212762/4972>
> 2016-10-19 7:42 GMT-05:00 Neumann, Andreas <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>:
> Good idea to use a virtual layer for that! It is probably also
> more efficient than a QGIS expression.
> Just to understand the virtual layers correctly:
> when is the query behind the virtual layer executed?
> - at every redraw?
> - once at creation?
> - at project reload?
> Aren't the virtual layers automatically updated, at least when the
> project reloads?
> Are the results cached or not?
> Would also make sense to add a "update" option for a virtual
> layer, if that doesn't exist yet.
> Greetings,
> Andreas
> On 2016-10-19 14:32, Nathan Woodrow wrote:
>> Maybe using a virtual layer query via DB Manager will work. You
>> have full SQL join support. Speed isn't always the best but gives
>> you the full power of SQL which is the correct way to do this IMO.
>> E.g SELECT LayerA.id, COUNT(*) FROM layerA
>> JOIN layerB ON ST_WithIn(layerA.geometry, layerB.geometry)
>> GROUP BY layerA.type
>> Although you can't do an update but you can make a new layer with
>> the new counts.
>> - Nathan
>> On Wed, Oct 19, 2016 at 10:22 PM, Neumann, Andreas
>> <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>> Well yes - but that is not a "live" point in polygon. It
>> create separate layers which need to be kept up-to-date.
>> Harrissou was after a "live" point in polygon, which is
>> automatically kept up-to-date through a QGIS expression.
>> Maybe Nyall knows how to write the correct aggregate
>> expression for that?
>> Greetings,
>> Andreas
>> On 2016-10-19 14:11, Nicolas Cadieux wrote:
>> Try this.
>> http://www.qgistutorials.com/fr/docs/points_in_polygon.html
>> <http://www.qgistutorials.com/fr/docs/points_in_polygon.html>
>> Nicolas
>> Le 19 oct. 2016 à 06:37, DelazJ [via OSGeo.org
>> <http://OSGeo.org>] <[hidden email]> a écrit :
>> Hi,
>> I have a polygon layer and a point one.
>> I'd like to calculate for each polygon feature, the
>> number of points that it covers. I thought the
>> aggregates functions could help me find an easier and
>> straight expression to perform this (without creating
>> intermediate layers) but I fail to find any correct
>> syntax.
>> I tried aggregate ('mypoint', 'count', "id",
>> intersects ($geometry, geometry($currentfeature)))
>> And many variants of the fourth option but It always
>> return the total of points or an error. Actually this
>> option is a filter and I wonder if i'm not missing a
>> "group by" option in the aggregate function (which
>> seems to be the appropriate one in my case). Is it
>> possible?
>> The work around I found is to populate an ad'hoc
>> field in the point layer with overlapping polygon id,
>> thanks to the SpatialJoin plugin, then I create a
>> one-to-many relation in the project between the two
>> layers in other to use relation_aggregate function.
>> But I expected something more direct.
>> Any hint, please?
>> Thanks,
>> Harrissou
>> Qgis-user mailing list
>> [hidden email]
>> List info:
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe:
>> If you reply to this email, your message will be
>> added to the discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Using-aggregates-functions-to-count-intersected-features-from-another-layer-tp5291420.html
>> <http://osgeo-org.1560.x6.nabble.com/Using-aggregates-functions-to-count-intersected-features-from-another-layer-tp5291420.html>
>> To start a new topic under Quantum GIS - User, email
>> [hidden email]
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Using aggregates
>> layer
>> <http://osgeo-org.1560.x6.nabble.com/Using-aggregates-functions-to-count-intersected-features-from-another-layer-tp5291420p5291443.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>> at Nabble.com.
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:
>> Unsubscribe:
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> http://twitter.com/GeoTux2
> http://about.me/germancarrillo
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161019/d6bb36a0/attachment.html>
