[Qgis-user] QGIS server: configuration of grid shift files for datum conversions
Richard Duivenvoorde
richard at duif.net
Mon Oct 24 01:01:26 PDT 2016
On 2016-10-24 06:23, Neumann, Andreas wrote:
> Hi,
> I have to configure QGIS server to properly handle grid shift files.
> In Switzerland we need to offer "old" and "new" coordinates (different
> datums) at the same time with our services and the conversion needs to
> be done with grid shift files or tin based interpolation.
> I know that I have to copy the CHENYX06a.gsb file to my proj lib, e.g.
> /usr/local/shar/proj - but how can I make QGIS Server to actually use
> this file? I assume that I need to copy an additional config file or
> SRS/grid shift file combinations to QGIS server and/or specify an
> environment variable - right?
> Are there any resources explaining how I can configure QGIS server to
> make use of these grid shift files?
> Thank you for any pointers!
Hi Andreas,
funny, in NL we just had a discussion about how to handle different
available datum transformation too last week...
we also recently got a grid shift file to better handle datum
transformation and I found this post of Sourcepole:
http://blog.sourcepole.ch/2014/02/18/ntv2-transformations-with-qgis/
Which I think answers your question (at least for the desktop side)
But from a mini presentation from somebody from our National Cadastre, I
actually draw the conclusion that the way QGIS represents CRS's is too
narrow/not complete...
Please correct me if I'm wrong, but a lot of 'On The Fly'-reprojections
actually need 2(!) proj configurations/steps:
- the projection parametes (mostly available in the epsg database)
- the datum transformation parameters (these is the 'towsg84...'-part,
AND only needed when you do an actual datum transformation, PARTLY
The last part can either be a list of parameters (to calculate it) OR
(as in your case and in the dutch preferred case) a grid shift file (as
proj can only handle one of these).
SO: for example for certain crs's (in QGIS the dutch one is called
epsg:28992) there is actually a SET of combinations available: the
projection and 4 or 5 transformations
(http://pix.toile-libre.org/upload/original/1477238061.png),
QGIS actually picks one (from qgis.db) of these and present them to the
user as THE epsg:28992 crs, while in our case this is actually not the
best fit, and in your case you actually want to pick two!
I understood that in ArcGIS, the user actually every time is presented
with a 'pick the right datum transformation' dialog as soon as the data
needs a datum transformatio. As a draw back: making it more difficult
for new users to pick the right one, BUT on the positive side making it
easier to pick the right projection/datumtransformation pair!
So what about using both worlds:
- in the qgis.db / crs table NOT use the projection-name as
crs-identifier (so NOT epsg:28992), BUT the combination of projection
AND datumtransformation, so in our case (28992_4833, 28992_15934, or
epsg28992_epsg4833, epsg28992_qgis0001 to be able to handle
projection/transformation combinations not available in the epsg db)
- and instead of current possibility to have a 'check'-box to have the
'select datum transformation' popup we make this available in the
'choose crs'-dialog with a button, and then 'remember' the last used
crs's (in which a crs is NOT only the projection anymore but a
projection/transformation combi)
IF QGIS starts using this combinations AND proj/gdal will ship all
gridfiles towgs-paramters etc etc, this will become a better world :-)
Does this make sense? Do others get excited from this idea too?
Regards,
ps about providing the gridfiles, I urge our national Kadaster to make
it available as treu open geodata, that is without a copyright
disclaimer, so it can be picked up by Debian and other distro's.
