[Qgis-user] Showing coordinates of the composer map item in a label
DelazJ
delazj at gmail.com
Thu Oct 27 08:51:22 PDT 2016
Hi all,
Is that possible to create a label which displays the x and y coordinates
of a selected map item in the composer.
I suspect x(@map_extent_center) to do the trick but I'm unable to find how
to call the map_extent_center variable in a label item as it's stuck to the
map item afaics.
Any tip, please?
Thanks,
Harrissou
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161027/caaf3833/attachment.html>
