[Qgis-user] Inverted polygons with draw effects in QGIS?
Chris Buckmaster chris.buckmaster at runnymede.gov.uk
Fri Oct 28 03:13:14 PDT 2016
Hi
I am using the inverted polygon symbol so I can symbolise outside of my polygon area which works well - I would also like to use the draw effects so I can include an outer glow and shadow around my polygon area but when I turn these on, the inverted style stops to display and reverts back to it symbolising my polygon area. I am not sure if this is an issue or just how the symbology works in QGIS?
How can I set it so that I can use the inverted polygon to style the area outside of my polygon, as well as include a glow / shadow on my polygon area so it appears to pop up from the surface?
Thanks, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161028/6af21691/attachment.html>
