[Qgis-user] clip still not working on osm shape
DelazJ
delazj at gmail.com
Thu Sep 1 06:31:46 PDT 2016
Reginald, in QGIS, Layer menu --> Save As ... (or simply a right-click on
the layer) helps you create a reproject the layer in another projection.
This is an easy way you could (actually) change the crs of your layers.
Once done, the clip process should have succeeded.
Changing the projection in the layer properties is not the way to do it.
2016-09-01 14:35 GMT+02:00 Reginald Carlier <
Reginald.Carlier at ingelmunster.be>:
> Hi,
> I found that the problem was the conversion of the CRS. When I select the
> shape of the town (Lambert 72) in QGIS Browser and choose WGS 84 as CRS the
> extent is still in Lambert coordinates. I tried the same in ArcMap and
> there I got the same result. Then I tried a function in the toolbox under
> Data Management > Projections and Transformations > Project where you can
> choose the CRS and also the transformation algorithm. Then the shape of the
> town was shown in the right spot. I wonder if there is such a tool in QGIS.
> Regards,
> Reginald Carlier
> Deskundige GIS
> [image: logo Ingelmunster]
> Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
> T +32 51 33 74 39 www.ingelmunster.be
> <https://www.facebook.com/Ingelmunster/>
> <https://plus.google.com/+ingelmunster>
> <https://www.instagram.com/ingelmunster/>
> <https://www.pinterest.com/ingelmunster/>
> <https://twitter.com/ingelmunster>
> *Van:* Nicolas Cadieux [mailto:nicolas.cadieux at archeotec.ca]
> *Verzonden:* donderdag 1 september 2016 13:36
> *Aan:* Reginald Carlier
> *Onderwerp:* Re: clip still not working on osm shape
> Hi,
> Are you running the latest Qgis 2.16? If so, vector tool should be in the
> processing toolbox and not in the vector menu. I have only worked one day
> with 2.16 but it was long enough to see that it needed a complete removal
> of all previous versions as the menu had a mixe of the old and the new
> version. After that, vector tools disappeared from the vector menu and
> reappeared in the new processing menu. I had read about this in a French
> blog so I was expecting it. Could this be the cause of your problem?
> If not, make sure both layers are in the same CRS (like you did) but that
> they also align properly when the "CRS on the fly" is not activated. Try
> loading only those two layers. You could test to see if it's the osm file
> format that is giving you problems by testing the two .shp file.
> Nicolas
> Envoyé de mon iPad
> Le 1 sept. 2016 à 05:33, Reginald Carlier <Reginald.Carlier@
> ingelmunster.be> a écrit :
> Hi Nicolas,
> I changed the CRS of the shapefiles so they match (EPSG 4326).
> It takes about 30 seconds before the algorithm (Vector > Geoprocessing >
> Clippen) finisches.
> Then it loads the resulting shapefile in QGIS but the attributetable is
> empty and the resulting shp is 1 kB.
> It looks as the Clip function doesn’t work.
> Regards,
> Reginald Carlier
> Deskundige GIS
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160901/2af6d8ff/attachment.html>
