[Qgis-user] Wrong retrieving of wms legend
Andrea Peri aperi2007 at gmail.com
Sat Sep 3 07:08:43 PDT 2016
Hi Richard.
Effectivelly I tested your wms and using it the legend is correctly
retrieved only for the layer choose.
I use qgis 2.16.1.
After I re-test my original url:
(this)
http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc
And again I see the qgis retrieve ALL the legend of all the layers.
I tested other wms of our set of wms service and seem only this has
that problem.
So I do some more proof tested.
And found where is the ISSUE.
QGIS wrong to get the legend when the layer wms requested HAS NOT A LEGEND.
Infact the issu happened when I ask any layer of our wms that is a
RASTER LAYER with no legend defined.
Instead not happened when the layer wms is of a vector dataset (where
the legend happened).
SO If you whould test and see the issue you should use our wms service:
and choose the layer
rt_ofc.1954
that return the orthophoto imagery of the year 1954.
With this layer the qgis will retrieve ALL the legends of the wms service.
Instead if you choose the layer
rt_ofc.1954.qu
that is a vector dataset (quadre of union)
qgis correctly retrieve only its own legend.
Please can you confirm this ?
Thx
A.
2016-09-03 9:51 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 31-08-16 21:10, Andrea Peri wrote:
>> Hi,
>> I notive that in the qgis 2.14.5 and in the qgis 2.16.1
>> when adding a layer wms choosing from a list of layers available in
>> the wms service connected,
>> qgis retrieve as legend of the layer ALL the legends of all the wms
>> layer available in the wms service.
>> Using the 2.8 QGIS version, the legend is retrieve correctly (only the
>> layer choosed).
>> Someone can confirm this as an issue ?
> Hi Andrea,
> nope, I have 2.16.1 here, and for example this wms:
> https://geodata.nationaalgeoregister.nl/bestuurlijkegrenzen/ows?SERVICE=WMS&
> I can choose either provincies or landsgrenzen (provinces or country
> borders), from that same server and both have their own legend.
> Do you have a WMS url for which this happens for you?
> What if you look at the capabilities of that service and do the
> getLegendGrapicRequest by hand. Is it also wrong?
> Else: create a good issue, with url's screendumps etc etc
> Regards,
Andrea Peri
qwerty àèìòù
