[Qgis-user] qlrbrowser not working anymore
    Reginald Carlier
    Reginald.Carlier at ingelmunster.be
    Tue Sep  6 07:10:13 PDT 2016
Here is some additional information I found in the log panel:
Processing Tab:
2016-09-06T15:36:48          2        Probleem met installatie van OTB: OTB werd niet gevonden of is niet correct geïnstalleerd
Seems like Orfeo Toolbox is used by some plugin and is not installed
Python warnings:
2016-09-06T15:36:45 1 warning:C:\OSGEO4~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py:844: PendingDeprecationWarning: This method will be removed in future versions. Use 'elem.iter()' or 'list(elem.iter())' instead.
for include in elem.getiterator("include"):
traceback: File "<string>", line 1, in <module>
File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 333, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:/Users/reginaldc/.qgis2/python/plugins\QlrBrowser\__init__.py", line 34, in classFactory
from .qlrbrowser import QlrBrowser
File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 607, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "C:/Users/reginaldc/.qgis2/python/plugins\QlrBrowser\qlrbrowser.py", line 32, in <module>
from .ui.dockwidget import DockWidget
File "C:/Users/reginaldc/.qgis2/python/plugins\QlrBrowser\ui\dockwidget.py", line 31, in <module>
os.path.dirname(__file__), 'dockwidget.ui'))
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\PyQt4\uic\__init__.py", line 210, in loadUiType
winfo = compiler.UICompiler().compileUi(uifile, code_string, from_imports, resource_suffix)
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\PyQt4\uic\Compiler\compiler.py", line 139, in compileUi
w = self.parse(input_stream, resource_suffix)
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py", line 933, in parse
actor(elem)
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py", line 844, in readResources
Plugins:
2016-09-06T15:36:44            0          Geladen GPS-gereedschap (Pad: C:/OSGEO4~1/apps/qgis/plugins/gpsimporterplugin.dll)
2016-09-06T15:36:44            0          Geladen AutoFields (package: AutoFields)
2016-09-06T15:36:45            0          Geladen geopunt4Qgis (package: geopunt4Qgis)
2016-09-06T15:36:45            0          Geladen go2streetview (package: go2streetview)
2016-09-06T15:36:45            0          Geladen Instant Print (package: instantprint)
2016-09-06T15:36:45            0          Geladen Layer List (package: layerList)
2016-09-06T15:36:45            0          Geladen Qlr Browser (package: QlrBrowser)
2016-09-06T15:36:45            0          Geladen QTiles (package: qtiles)
2016-09-06T15:36:47            0          Geladen QuickOSM (package: QuickOSM)
2016-09-06T15:36:47            0          Geladen QuickMapServices (package: quick_map_services)
2016-09-06T15:36:47            0          Geladen DB Manager (package: db_manager)
2016-09-06T15:36:47            0          Geladen GdalTools (package: GdalTools)
2016-09-06T15:36:47            0          Geladen MetaSearch Catalogue Client (package: MetaSearch)
2016-09-06T15:36:49            0          Geladen Processing (package: processing)
Userexpressions:
2016-09-06T15:36:44            1          De gebruikersexpressie adressen is niet geldig
                                     File "C:/OSGEO4~1/apps/qgis/./python\qgis\user.py", line 48, in load_user_expressions
                                       __import__("expressions.{0}".format(name), locals(), globals())
                                     File "C:/Users/reginaldc/.qgis2/python\expressions\adressen.py", line 12
                                       Function FindLabel ( [GEBOUWNR] )
                                   IndentationError: unexpected indent
I used the expressions tool for a layer of addresses. Because I copied the expression from ArcMap it was not working, so I removed the layer. Somewhere the system must have kept track of this erroneous expression. Where can I remove it?
Regards,
Reginald Carlier
Deskundige GIS
[http://www.ingelmunster.be/ingelmunster.gif]
Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
T +32 51 33 74 39 www.ingelmunster.be<http://www.ingelmunster.be>
[http://www.ingelmunster.be/fb.jpg]<https://www.facebook.com/Ingelmunster/> [http://www.ingelmunster.be/go.jpg] <https://plus.google.com/+ingelmunster>  [http://www.ingelmunster.be/in.jpg] <https://www.instagram.com/ingelmunster/>  [http://www.ingelmunster.be/pi.jpg] <https://www.pinterest.com/ingelmunster/>  [http://www.ingelmunster.be/tw.jpg] <https://twitter.com/ingelmunster>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160906/0372d2f5/attachment.html>
