[Qgis-user] Linear referencing in QGIS
Régis Haubourg regis.haubourg at gmail.com
Fri Sep 9 02:47:56 PDT 2016
2016-09-08 15:15 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 08/09/2016 12:57, Bernhard Ströbl ha scritto:
> > Hi Paolo,
> > I included the code in a small plugin for you to check it out. It's on
> > github: https://github.com/bstroebl/Station
> > Could certainly be improved by snapping to the line (snap to segment
> > must be turned on).
> Thanks Bernhard.
> IMHO we should heve in core a similar solution, to make LRS usage smoother.
> All the best.
Thanks Bernard for sharing python snippets.
What I had in mind was a core widget in field editors so that users can
make a form with a pick up tool that allow to fill measure or z value
without any coding.  Anyway, sharing and advertising a code snippet doing
that will allow to have a better idea of how this can work.
Cheers
Régis
Mon adresse principale devient désormais regis.haubourg at gmail.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160909/76c9542c/attachment.html>
