[Qgis-user] Another Raster Problem
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Sep 12 06:30:14 PDT 2016
Hi Heather,
Over the weekend, I have seen a number of posts relating to 32 windows and rasters. There seems to be a problem with the package for the 32 windows environment. I believe they are working on it. Try reloading the install package and try again. I imagine you could use 2.12 in the mean time if that does not work.
Nicolas
Envoyé de mon iPad
> Le 12 sept. 2016 à 08:52, Heather Hillers [via OSGeo.org] <ml-node+s1560n5285326h67 at n6.nabble.com> a écrit :
> Hi,
> I have a set of tifs that cause an AppCrash on load to 2.14.6 and 2.16, either immediately on load or shortly after. I can load and work with these files without problem in QGIS 2.8.6
> I have produced 4 small hillshade tifs, each less than 1000 Kb in size. Each has a world file and a kml in the same directory. I have uploaded them to https://github.com/HeatherHillers/QGISRasterLoadCrash
> We have a networked Windows 7 32bit environment running OSGeo4W (qgis-ltr) as well as a local Windows 7 32 bit environment running OSGeo4W (qgis-ltr and qgis) and the problem shows in all 3 installations. The QGIS 2.8 that loads the files successfully is also running on a networked Windows 32bit environment. Storing the files on a networked vs. local drive doesn’t seem to impact the problem.
> The CRS of the files is 32619. I have tried eliminating Reprojection in my settings and in the project settings.
> I have produced the data by following the instructions in the following 3 (excellent!) tutorials from LASTools, using their test data. I didn’t get any errors in generation, and the tiles look very nice in 2.8, so I don’t .think. they are corrupt.
> http://rapidlasso.com/2013/04/20/tutorial-quality-checking/
> http://rapidlasso.com/2013/10/13/tutorial-lidar-preparation/
> http://rapidlasso.com/2013/10/20/tutorial-derivative-production/
> Thoughts?
> Thanks,
> Heather
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Another-Raster-Problem-tp5285326.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Another-Raster-Problem-tp5285326p5285335.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160912/778c6f75/attachment.html>
