[Qgis-user] Ubuntu updating instructions
Randal Hale
rjhale at northrivergeographic.com
Tue Sep 13 09:08:51 PDT 2016
I don't think it's necessarily ignorance - the word unstable means "no
stable; not firm or firmly fixed; unsteady" [1]. At my old place of
employment software that was in any way related to the work "unstable"
would never get installed or tested.
UbuntuGIS-unstable isn't unstable. BUT - it has that word associated
with it. It is confusing for users. If we told the windows users to grab
their installation files from a directory labeled *unstable* there would
be much unhappiness.
[1] http://www.dictionary.com/browse/unstable
On 09/13/2016 10:51 AM, Blumentrath, Stefan wrote:
> And if I may add:
> Even if the users are aware of the fact that ubuntugis-unstable
> contains the current releases, it can be hard to impossible to
> convince a GIS-ignorant system administrator that it is OK to install
> “unstable” packages.
> But this issue is not a QGIS issue I guess...
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Randal Hale
> *Sent:* 13. september 2016 16:45
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Ubuntu updating instructions
> On 09/13/2016 10:23 AM, Jürgen E. Fischer wrote:
> Hi Randal,
> On Tue, 13. Sep 2016 at 00:21:21 -0400, Randal Hale wrote:
> It's a little bit confusing. There are like three repositories:
> stable, unstable, and testing. Testing you don't want (unless you
> want to test packages). Typically stable is a bit older. Unstable is
> current. Which doesn't really make sense - but that's the way it is.
> Not like it matters much in this case.
> We have packages in qgis.org/debian/ against the plain versions of the
> distributions (debian and **ubuntu**) and in qgis/ubuntugis/ packages against
> newer dependencies from - and only from - ubuntugis-unstable.
> Looks like it's hard for people to accept that there are also ubuntu packages
> in a directory called debian and that probably makes them jump on the other
> because it has ubuntu in it's name.
> I was thinking about it last night (and I was up way to late) and it
> is a bit confusing for the casual user. They've installed Ubuntu (or
> mint/debian/xubuntu/etc) and they may not understand ubuntu is based
> off debian. So like you said - they see debian but want to use Ubuntu.
> They go to UbuntuGIS and they see the repositories for UbuntuGIS and
> the choice is unstable (and no one likes unstable software) and stable
> (which doesn't contain the newest software). So you end up going "Use
> Unstable because it's stable and current".
> Under my /etc/apt/sources.list.d directory I made a qgis.list file
> and put the following in there:
> debhttp://qgis.org/debian xenial main
> debhttp://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu xenial main
> Why? That are the packages not based on ubuntugis with the dependencies from
> ubuntugis.
> Do I have this wrong? I thought I had the repositories for the install
> correct based off the directions on qgis.org. Which I could completely
> have it wrong. With the above repos I'm getting QGIS 2.16.x and GDAL
> 2.1.x.
> Jürgen
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
Randal Hale
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160913/2f23acb8/attachment.html>
