[Qgis-user] Feature labels using joined data
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Sep 19 14:47:03 PDT 2016
Is must block because the join file needs to be modified by the new label positions. Like you say, I imagine, it's a read only connection but I am not sure.  I would try joining with a dbf file but you will probably have the same results.  You could join the files then save them but that would give you multiple versions.  Perhaps trying a database would solve the problem.
Perhaps the idea would be to have multiples x and y labels columns for different projects or else to export the label column as .csv that you could join later...
Good luck
Envoyé de mon iPad
> Le 19 sept. 2016 à 16:51, Martin Stubbs [via OSGeo.org] <ml-node+s1560n5286759h90 at n6.nabble.com> a écrit :
> HI,
> I have a dataset of point features that I label with their name. I am
> producing documents in a number of different formats using this data and
> I need to be able to move the label positions.
> To avoid having multiple label_x and label_y in the original dataset I
> was hoping to join a different label datafile, containing a label_x and
> label_y,  to the dataset in each project.
> Unfortunately when I use the "joined" locations I am not able to use the
> "move label" feature to edit the label x and y that is stored in the
> joined file. I have tried csv and shapefile formats for the datafile.
> Should I be able to update the data in a joined file or is this a read
> only connection?
> Any suggestion on managing multiple label positions appreciated.
> Thanks
> Martin
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Feature-labels-using-joined-data-tp5286759.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Feature-labels-using-joined-data-tp5286759p5286774.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/736ae8f1/attachment.html>
