[Qgis-user] qgsRelationReferenceWidget
Tyler Veinot tylerkveinot at gmail.com
Tue Sep 20 04:46:10 PDT 2016
I can do that Matthias, probably wont be until around noon AST.
Tyler
On Tue, Sep 20, 2016 at 8:26 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Tyler,
> The message is not related to virtual fields.
> Can you open an issue report and specify exactly how to reproduce the
> issue?
> Thank you
> Matthias
> On 09/20/2016 01:13 PM, Tyler Veinot wrote:
> > I don't know what I am doing wrong here, I set this up multiple times
> > using every different relationship I have. I even rebuilt the design
> > using simpler tables. The drop down doesn't populate and when I try to
> > use the green "plus" button all I get is a mini dump and a crash. The
> > log file says in the exception "The thread tried to read from or write
> > to a virtual address for which it does not have the appropriate access".
> > I do have a virtual field but I am not writing to it, it is just there
> > to display the table data in a more appealing way, and I am not writing
> > or using it in the relationship so I cannot see it being an issue. I can
> > also write data from within QGIS directly to the tables so I must have
> > permission.
> > Any thoughts?
> > Tyler
> > On Fri, Sep 16, 2016 at 7:44 AM, Tyler Veinot <tylerkveinot at gmail.com
> > <mailto:tylerkveinot at gmail.com>> wrote:
> >     Andrew;
> >     Well that was simple, thank you. I didn't even think to look there;
> >     I was trying to add a standard push button and associate it with
> save.
> >     Now I just have to solve everything else.
> >     Thanks again.
> >     Tyler
> >     On Thu, Sep 15, 2016 at 4:22 PM, Andrew <amcaninch at gmail.com
> >     <mailto:amcaninch at gmail.com>> wrote:
> >         Regarding your second question, in QTDesigner you can change the
> >         default buttonBox properties to include a "Save" or "Apply"
> button.
> >         On Thu, Sep 15, 2016 at 8:17 AM, Tyler Veinot
> >         <tylerkveinot at gmail.com <mailto:tylerkveinot at gmail.com>> wrote:
> >             Not having much luck with this, I managed to get the
> >             qgsRelationReferenceWidget to show me a list of addresses
> >             but I cannot get it to write the wo_id and unique_id to my
> >             table.
> >             On a different note, is there an ability to create a "save"?
> >             the "ok" button closes the form completely. I just want to
> >             "save" my work order to write its values to the wo_table and
> >             continue editing.
> >             Tyler
> >             On Tue, Sep 13, 2016 at 9:35 AM, Tyler Veinot
> wrote:
> >                 Matthias;
> >                 Ooop's I forgot to add that I was building the form in
> >                 Qt Designer and not from within QGIS, although with this
> >                 information is really good and is showing me things I
> >                 didn't quite understand before. I am a very visual
> >                 person I find it hard to understand things without
> >                 seeing it in a diagram or some other example. Took me
> >                 forever to figure out dog gears and differential gears
> >                 until I tore apart my first bicycle and rear end; as
> >                 soon as I seen it I got it.
> >                 This is my relationship defined in QGIS thus far....
> >                 When I add an address to the work order I need to write
> >                 the wo_id of my work order and my unique_id of my
> >                 address to my jtbl_cwo table. So when I, or someone,
> >                 opens a work order it will show them a list of address
> >                 associated to that one work order. Also need to do the
> >                 same thing with primary assets, so the form will look
> >                 something like this in QGIS;
> >                 ​Of course the unique_id will be referencing a value
> >                 from the civic_points "address" but that is that I am
> >                 trying to accomplish. I did it in LibreOffice and Access
> >                 but I would like to consolidate it all into one database
> >                 with one interface, i.e. QGIS. That way I can edit
> >                 features, add assets, and do most of my daily tasks in
> >                 one application.
> >                 Is there an example of this being done in QGIS anywhere?
> >                 Tyler
> >                 On Tue, Sep 13, 2016 at 8:37 AM, Tyler Veinot
> >                 wrote:
> >                     Matthias;
> >                     Thanks, I don't know what I would do without you!
> >                     Coding isn't normally an issue but that tutorial
> >                     didn't quite explain where to put the coding. When I
> >                     opened the UI file in IDLE it looked like XML, and
> >                     there were no other files associated with the form.
> >                     I also opened the "see code" option and it was the
> >                     same looked like XML; it might have been C++ but I
> >                     have no training or experience with C++ so I
> >                     wouldn't know if it looked similar to XML from the
> >                     "untrained eye" point of view.
> >                     Going to be doing some testing on the versioning bit
> >                     here this week, hope to have something a little more
> >                     concrete to say about it soon.
> >                     Tyler
> >                     On Tue, Sep 13, 2016 at 2:58 AM, Matthias Kuhn
> >                     <matthias at opengis.ch <mailto:matthias at opengis.ch>>
> >                     wrote:
> >                         Hi Tyler,
> >                         Here is the blog post I wrote for this feature:
> >                         http://blog.vitu.ch/10112013-1201/qgis-relations
> >                         <http://blog.vitu.ch/10112013-
> 1201/qgis-relations>
> >                         Just configuration, no coding, I hope that helps.
> >                         Cheers
> >                         Matthias
> >                         On 12/09/16 22:56, Tyler Veinot wrote:
> >>                         All;
> >>                         Trying to make a form for QGIS that has a form
> >>                         within a form so that I can link and display
> >>                         entries from another table similar to this
> >>                         tuorial;
> >>                         https://medspx.fr/blog/Qgis/
> better_qgis_forms_part_three/
> >>                         <https://medspx.fr/blog/Qgis/
> better_qgis_forms_part_three/>
> >>                         I think I need to use
> >>                         qgsValueRelationRefernceWidget but I cannot
> >>                         find any tutorials on it.
> >>                         Thanks;
> >>                         Tyler
> >>                         _______________________________________________
> >>                         Qgis-user mailing list
> >>                         Qgis-user at lists.osgeo.org
> >>                         <mailto:Qgis-user at lists.osgeo.org>
> >>                         List info: http://lists.osgeo.org/
> mailman/listinfo/qgis-user
> >>                         <http://lists.osgeo.org/
> mailman/listinfo/qgis-user>
> >>                         Unsubscribe: http://lists.osgeo.org/
> >                         List info:
> mailman/listinfo/qgis-user <http://lists.osgeo.org/
> >                         Unsubscribe:
> >             Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >             List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >             <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> >             Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160920/d7c570a8/attachment.html>
