[Qgis-user] build QGIS Server - can QT support be disable?
    Luigi Pirelli
    luipir at gmail.com
    Thu Sep 22 14:29:37 PDT 2016
QT is a framework not only GUI library and qgis server, that use qgis
libs, is heavely based on QT, so you need it!
the simpler solution is to run qgi server in a docker container;
e.g.
https://github.com/kartoza/docker-qgis-server
or
https://github.com/elpaso/qgis-server-docker
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 22 September 2016 at 21:15, Eduardo Kanegae
<eduardo.kanegae at gmail.com> wrote:
> hi there,
> I'm running a CentOS 6.8, kernel 2.6.32 x86_64 and I'm trying to build
> QGIS Server, based on qgis LTR 2.14.6 sources.
> After trying to configure using ccmake, I got the error:
> CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:108
> (message):
>    Could NOT find Qt4: Found unsuitable version "4.6.2", but required is at
>    least "4.8.0" (found /usr/bin/qmake-qt4)
>  Call Stack (most recent call first):
>    /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:313
> (_FPHSA_FAILURE_MESSAGE)
>    /usr/share/cmake/Modules/FindQt4.cmake:1393
> (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
>    CMakeLists.txt:277 (FIND_PACKAGE)
> The default yum install gaves me qt4.6.x but I was wondering if is
> there any way to turn off QT support because I won't need any GUI
> functions,
> I just need QGIS Server at this machine. Or am I wrong? Do we need QT4
> or QT5 for building  QGIS Server too, as well in QGIS Desktop cases?
> thanks in advance,
> Eduardo Kanegae
> http://www.webmapit.com.br | @webmapit
> https://soundcloud.com/ekanegae
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
