[Qgis-user] Atlas - generation for one object
    Phil (The Geek) Wyatt
    phil at wyatt-family.com
    Thu Sep 22 16:29:12 PDT 2016
You can also create that polygon grid layer by using the Vector, Research Tools, Vector grid and basing the grid on the bounds of your single object.
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of AVICOMARTIN
Sent: Friday, September 23, 2016 1:00 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Atlas - generation for one object
Yes, there is.
You can define a layer with rectangles that cover your linear object (size and position acording to the scale you want) and create atlas using this rectangle layer
El 22/09/2016 a las 14:24, Szymon Guza escribió:
Hello,
I want to create an atlas for one object. This object is linear (transmedia - fiber cable) and I want to generate its course on several pages in fixed scale (because the cable is "too long" to fit on one page).
Is there a possibility to do that?
Szymon
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160923/fb27aabc/attachment.html>
