[Qgis-user] Cannot load WFS data
ralfwessels gis at ralf-wessels.de
Fri Sep 23 07:16:08 PDT 2016
Hi Heinrich,
yes all the  1.369 polygon objects were loaded and rendered correctly in my
QGIS, when I used the filter "BEZIRK"  = 'Mitte'.  I also tried it with
"BEZIRK"  = 'Pankow' and it also worked out well, but it took 2:13 min to
load the 2.698 poly objects.
In QGIS you can set an individual timout for network requests under Settings
> Options > Network Menu (Einstellungen > Optionen > Netzwerk). Default is
60000 ms (60 seconds).
In my QGIS I set the timeout up to 6.000.000 to load bigger data or in case
the internet connection is slow.
When I tried to load the WFS-data with default timeout, after 60 seconds I
got the (german) error message "Zeitüberschreitung bei
Netzwerkabfrage.......dauerte zu lange"
Ralf
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-load-WFS-data-tp5287424p5287460.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
