[Qgis-user] field datatype issue
James Wood jwood911 at gmail.com
Sat Sep 24 15:00:54 PDT 2016
If you load in the file geodatabase feature class, does QGIS see the correct values? If so, is there any reason not to edit it as a file geodatabase in QGIS?
Best regards,
James
Sent from my iPhone
> On Sep 23, 2016, at 06:39, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Hello;
> I have a shapefile I exported from a filegeodatabase that has been edited by a another individual and returned to me. I appended the edits to the corresponding featureclass in the geodatabase using ArcDesktop then exported a new shapefile to continue editing. The new shapefile for some reason will only hold 7 digits yet there are numerous 10 digit numbers pre-existing. The field description is double, real, 18 so why will it only accept 7 digits? The field is only suppose to be a scale of 10 with a precision of 0, ArcDesktop sees this but QGIS insists all values are XXXXXXXX.00000000000
> Is there a way I can change the field type?
> Has anyone had this happen to them before and have a way to fix it?
> How can I prevent this from happening again?
> Thanks
> Tyler
> (BTW: I didn't originally build this featureclass, if I had I would have used longInt and not double precision in the first place.)
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
