[Qgis-user] QGIS 2 master: Identify tool and highlights
Tyler Veinot
tylerkveinot at gmail.com
Tue Sep 27 09:16:56 PDT 2016
Settings > Options > Map Tools (Left Hand Side Panel) At the top you should
see identify and a drop down for highlight color. If this color is set to
100% Transparent then it would work as if there was no highlight. Other
than that I see no other way to turn off the highlight so check there;
maybe you accidentally made your highlight transparent. To add to that,
white would look like there was no highlight on if the background color was
also white, its effect is a very light ghosting of the feature when
identified; easily missed.
Tyler
On Tue, Sep 27, 2016 at 12:50 PM, Neumann, Andreas <a.neumann at carto.net>
wrote:
> Thanks for checking. Is there some configuration that might disable this
> highlighting?
> I was sure I had this working, but now it doesn't. I checked all my
> versions I have: 2.14, 2.16, master 2. Neither one works.
> Andreas
> On 2016-09-27 17:43, DelazJ wrote:
> Hi,
> Andreas, I can't confirm (windows 10 and 2.16.3)
> Features are highlighted when I hover over their id in the context menu.
> Regards,
> Harrissou
> 2016-09-27 17:36 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
>> Hi,
>> I am sure that in a past QGIS 2x version, when the identify tool was set
>> to "layer choice" that one would have gotten a highlight of the selected
>> feature from the context menu.
>> Now, with the current 2.x master (and with 2.16 and 2.14) on Windows, the
>> highlight of the object is gone ;-( so now there is no way to find out what
>> feature I am selecting. The highlight now only displays after I selected
>> the entry, which is not so useful than the previous behavior.
>> Can someone confirm? Or is it just a misconfiguration on my side?
>> Thank you for any hints,
>> Andreas
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160927/e41f490b/attachment.html>
