[Qgis-user] QField
Reginald Carlier
Reginald.Carlier at ingelmunster.be
Tue Sep 27 04:26:02 PDT 2016
Thanks Fabrice,
I will certainly try mbtiles.
Regards,
Van: F T [mailto:oukile at gmail.com]
Verzonden: vrijdag 23 september 2016 11:20
Aan: Reginald Carlier
Onderwerp: Re: [Qgis-user] QField
Hello
I'm also disapointed with gptk raster : too slow, not easy to prepare
For QField, we rather use .mbtiles format, created from QGis and the QTiles extension.
All formats that QGis uses can be converted in .mbtiles, it's very very easy to prepare.
QField uses .mbtiles raster very well, it's fast to display
Tested with a 4Go .mbtiles
Fabrice
2016-09-22 9:32 GMT+02:00 Reginald Carlier <Reginald.Carlier at ingelmunster.be<mailto:Reginald.Carlier at ingelmunster.be>>:
Thanks Andreas,
Creating a Geotiff with pyramids did the trick. The only disadvantage is that it created a file of about 1.7 GB (the original was 90 MB).
Now I am ready to test the app ☺.
Regards,
Van: Neumann, Andreas [mailto:a.neumann at carto.net<mailto:a.neumann at carto.net>]
Verzonden: woensdag 21 september 2016 16:19
Hi Reginald,
Did you create pyramids in the gpkg rasters?
Generally, Geotiff should be well supported - definitely more tested than gpkg rasters. I had a 1GB geotiff on qfield (on SD-Card) and it displays fast. I haven't tested vrt files with geotiffs - if it works as well?
Andreas
On 2016-09-21 15:44, Reginald Carlier wrote:
Hi Erwan,
You can look in the list of last week where I posted a couple of questions about qfield and was pointed to the right website for documentation.
I succeeded to publish a map on my phone but the aereal photo which was published as a gpkg file doesn’t render. When I use the raster.gpkg on my desktop it renders but very slow.
The gpkg file was created from a 90 MB jp2 file.
Regards,
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160927/d746f3ae/attachment.html>
