[Qgis-user] Using QGIS/Atlas system-vars?
Andreas Neumann
a.neumann at carto.net
Thu Sep 29 02:46:13 PDT 2016
Hi Mike,
And what exactly is your problem?
@atlas_pagename: did you define an expression for a pagename? If now, it
will stay empty as you observed.
@layout_page: how many pages does your layout contain? If your layout
has only 1 page it will always return 1
@layout_numpages: see above. Depends on how many pages your layout has.
If you want to get the nth feature, you have to use
@atlas_featurenumber, resp. @atlas_totalfeatures. If your layout
contains more than one page and you want to have the exact pagenumber,
you have to calculate the number, using @atlas_featurenumber,
@layout_numpages and @layout_page to get the actual page number.
Greetings,
Andreas
Am 29.09.2016 um 11:01 schrieb Elstermann, Mike:
> Hi,
> I want to use in QGIS/Atlas system-vars. In my textbox I write this:
> Halle (Saale), [% "name" %] [% @layout_page %] ... [% @atlas_pagename
> %] ... [% @layout_numpages %] ... [% @layout_pageheight %] ... [%
> @layout_pagewidth %]
> Results:
> * [% "name" %] works OK, gives correct names
> * [% @layout_pageheight %] works OK, gives correct pageheight
> * [% @layout_pagewidth %] works OK, gives correct pagewidth
> * [% @layout_page %] gives only "1"
> * [% @atlas_pagename %] gives only ""
> * [% @layout_numpages %] gives only "1"
> Where is the/my fault?
> THX and best regards, mikeE., The geoObserver
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160929/1fb1343b/attachment.html>
