[Qgis-user] Problem with properityes
    Luigi Pirelli
    luipir at gmail.com
    Fri Sep 30 03:09:25 PDT 2016
hard to say without sample data that create you the problem... to try to
fix, you should allow others to repeat the issue with replicable steps on
sample data.
so your first step would be:
1) create a reproducible set of steps that create the problem against
shareble data
2) share you detailed configuration (OS data, how did you installed QGIS
and related packages... please add all details)
3) ask if other in similar condition can replicate the problem
4) try to do the same steps on another OSX laptop (or virtual machine) to
see if the problem can be replicated in a CLEAN install
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 30 September 2016 at 11:52, Alejandro Martorell Reig <
martorell3588 at gmail.com> wrote:
> Any idea?? Any solutions please? I need work with QGIS, but now Its
> imposible.
> Thank you for all
> El 27/9/16 a las 9:42, Alejandro Martorell escribió:
> I installed new OSX Sierra 10.12,  I can open properities now, but QGis is
> more unestable. For exemple, a lot of times I cant open old proyects or
> shapes, Qgis locked more times.
> What do you thing about this??
> Alejandro Martorell
> On Mon, Sep 26, 2016 at 4:16 PM +0200, "Alejandro Martorell Reig" <
> Versión de QGIS
>> 2.16.2
>> Rama del código de QGIS
>> Release 2.16 <https://github.com/qgis/QGIS/tree/release-2_16>
>> Compilado contra Qt
>> 4.8.6
>> Ejecutándose contra Qt
>> 4.8.6
>> Compilado contra GDAL/OGR
>> 2.1.1
>> Ejecutándose contra GDAL/OGR
>> 2.1.1
>> Compilado contra GEOS
>> 3.5.0-CAPI-1.9.0
>> Ejecutándose contra GEOS
>> 3.5.0-CAPI-1.9.0 r0
>> Versión del cliente PostgreSQL
>> 9.4.4
>> Versión de SpatiaLite
>> 4.3.0a
>> Versión de QWT
>> 6.1.3
>> Versión de PROJ.4
>> 492
>> Versión de QScintilla2
>> 2.9.3
>> El 26/9/16 a las 15:02, Luigi Pirelli escribió:
>> cut& paste the content of qgis->help>about
>> Luigi Pirelli
>> * Mastering QGIS:https://www.packtpub.com/application-development/mastering-qgis
>> On 26 September 2016 at 14:22, Alejandro Martorell Reig<martorell3588 at gmail.com> <martorell3588 at gmail.com> wrote:
>> Attache file wiht the error.
>> Need more??
>> El 26/9/16 a las 13:35, Luigi Pirelli escribió:
>> what OSX and share qgis->help->about list of loaded libs
>> regards
>> Luigi Pirelli
>> On 26 September 2016 at 12:26, Alejandro Martorell Reig<martorell3588 at gmail.com> <martorell3588 at gmail.com> wrote:
>> Good Morning,
>> I have a problem with QGIS long. Use mac. I have a lot of time and I worked
>> perfectly, from one day to another every time you try to open the properties
>> of a layer hangs and I have to close it, I can not change the properties of
>> the layers. It's annoying. I happened with the old version 2.14 and
>> yesterday install the new version 2.16 and I still have the same problem.
>> The problem is something that I have in the pc that causes a problem
>> generated in the installation. I have installed the kingchaos version and
>> another. I do not know what to do.
>> Como puedo entrar a lo que es el foro. No encuentro la dirección?
>> Un saludo y gracias
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160930/fa11c568/attachment.html>
