[Qgis-user] Database options
Michael Treglia
mtreglia at gmail.com
Fri Sep 30 11:46:14 PDT 2016
GeoPackage might have some utility - especially in being able to package up
data and share it (http://www.geopackage.org/). I haven't used it at all,
but have thought about it as I'm trying to make data more usable across
users and platforms... (It stores data in a SQLite db, and has support via
GDAL/QGIS, ESRI, and many other interfaces.)
Hope that helps - I'd be curious to hear others' experiences in working
with GeoPackage dbs
Mike
On Fri, Sep 30, 2016 at 2:37 PM, Tyler Veinot <tylerkveinot at gmail.com>
wrote:
> That was my thought for a solution, do the data entry in QGIS and use that
> as the primary got to for entry and data retrieval using data entry forms
> and widgets. Issue has been the m:n relationships. I downloaded postgreSQL
> portable to try and since upgrading to 2.16.3 I have not tried my SQLite
> forms to see if they work better as of yet; hoping to get to it this
> weekend but I got quite a bit of work to do before I can get back to it.
> Likely going to have to go with PostgreSQL; it is the only one that works
> well with both platforms.
> Tyler
> On Fri, Sep 30, 2016 at 2:27 PM, Alex M <tech_dev at wildintellect.com>
> wrote:
>> I looked for this unicorn many moons ago. It sadly doesn't exist. I have
>> not found any interface quite like Access (which I have successfully
>> used via ODBC to sqlite). Libre Base comes close but there's been many
>> years of them saying they'd implement sqlite as a 1st class db and no
>> movement, they always prefer Java based solutions it seems.
>> The conclusion I reached is that you need either a web or local
>> interface to your db. For data entry I looked into writing a custom
>> Python application with the widgets I wanted for data entry, a node type
>> app could work also (share code between a web interface and desktop
>> interface). One option would be to make custom forms, or a plugin for
>> QGIS and do all your data entry there.
>> For writing queries there's lots of GUI tools, I usually use Spatialite
>> GUI, QGIS QSpatialite Plugin, or Firefox SQLite Manager (non-spatial
>> queries only). But both of these would be terrible for mass data entry.
>> You could also, do a spreadsheet->csv->db script
>> Thanks,
>> Alex
>> On 09/28/2016 11:06 AM, Tyler Veinot wrote:
>> > Luigi;
>> > Thanks, I will give it a try. Also tried using using MS Access to
>> connect
>> > to the SQLite database following steps I found online using an ODBC
>> > connection. Got no useable sqlite3.dll found. It doesn't tell me where
>> it
>> > is looking or anything; the ODBC driver install did put an sqlite3.dll
>> in
>> > the system32 folder so I am not sure what the issue is, if the file is
>> not
>> > what access is looking for or if it is looking in the wrong spot for it;
>> > Libre seems to be able to find it no problem.
>> > Tyler
>> > On Wed, Sep 28, 2016 at 1:22 PM, Luigi Pirelli <luipir at gmail.com>
>> wrote:
>> >> Tyler may you try with latest backported bugfixes on sqlite ogr
>> >> provider? Probably related with your problem ("unable to commit
>> >> changes to the database"). Check if it is similar following these
>> >> steps: https://hub.qgis.org/issues/15351
>> >> regards
>> >> Luigi Pirelli
>> >> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
>> >> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>> >> * Stackexchange: http://gis.stackexchange.com/u
>> sers/19667/luigi-pirelli
>> >> * GitHub: https://github.com/luipir
>> >> * Mastering QGIS:
>> >> https://www.packtpub.com/application-development/mastering-qgis
>> >> On 28 September 2016 at 17:54, Tyler Veinot <tylerkveinot at gmail.com>
>> >> wrote:
>> >>> I would prefer to go with postgre but I think that is going to have to
>> >> be a
>> >>> future project; right now we use a file geodatabase because it can be
>> >> copied
>> >>> and distributed. Some of our PC's are disconnected from a network
>> and/or
>> >>> have very limited network access. To my knowledge I cannot just copy a
>> >>> Postgres, MySQL, Maria, or other like databases to a PC or tablet and
>> run
>> >>> them. I have run Postgre as a local service doing some testing and
>> >> playing
>> >>> but I have no place to put it for everyone to access, thats why I am
>> >> looking
>> >>> for a SQLite/File geodatabase type solution.
>> >>> SQLite's only issue is that the qgsEditRelationWidget and
>> >> qgsRelationWidget
>> >>> don't seem to respond well to it. I have tried a number of different
>> >> ways to
>> >>> make those features work and it always ends in either a crash with
>> >> minidump
>> >>> or "unable to commit changes to the database". LibreBase does not
>> >>> acknowledge SQLite's capabilities as a database; tried it with both
>> JDBC
>> >> and
>> >>> ODBC drivers. I can build but cannot edit tables, will not support
>> >> relations
>> >>> or SQL Queries containing inner, outer, or full joins.
>> >>> What about a GUI for SQLite? Something like Access for SQLite
>> databases?
>> >> If
>> >>> there was such a thing I could move the data entry to that; looks
>> like I
>> >>> have some googling to do.
>> >>> Tyler
>> >>> On Wed, Sep 28, 2016 at 12:01 PM, John Harrop <jcharrop at gmail.com>
>> >> wrote:
>> >>>> You could run it as a local server and it is available on all major
>> >>>> platforms. If you need a server with wider access you could look at
>> AWS
>> >>>> (even the free tier will give you some RDB service). The Postgresql
>> >>>> supported there has the PostGIS extension ready to load so for us it
>> >> was a
>> >>>> logical choice for hosting spatial data.
>> >>>> John Harrop
>> >>>>> On Sep 27, 2016, at 8:09 AM, Tyler Veinot <tylerkveinot at gmail.com>
>> >>>>> wrote:
>> >>>>> Hello;
>> >>>>> I need some database options; I tried PostgreSQL, HSQL,
>> >>>>> SQLite/Spatialitem, Access (mdb/accdb) and what I get is either it
>> >> works
>> >>>>> well with QGIS and doesn't work well at all with LibreBase or vice
>> >> versa,
>> >>>>> with the exception of PostgeSQL which works well with both but I
>> >> don't have
>> >>>>> a server to run it on. Are there any other databases that you can
>> >> suggest?
>> >>>>> With no server at the moment I would like something that exists in a
>> >> file in
>> >>>>> the same way; SQLite, Access, or file geodatabases do, but also
>> >> compatible
>> >>>>> with QGIS and LibreBase.
>> >>>>> Thanks;
>> >>>>> Tyler
>> >>>>> _______________________________________________
>> >>>>> Qgis-user mailing list
>> >>>>> Qgis-user at lists.osgeo.org
>> >>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160930/b9dd7884/attachment.html>
