[Qgis-user] Unique IDs in a PostGIS view
Árni Geirsson
arni at alta.is
Wed Apr 12 04:13:10 PDT 2017
Thanks for the suggestion Karl.
I have used row_number() also but in the case of dumping vertex points from
a line, multiple points are created from each line feature and therefore,
the row_number is repeated for all points on the same line.
Árni
Árni Geirsson
*Alta ehf* // +354 582 5000 // +354 897 9549
On 12 April 2017 at 09:45, Karl Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se> wrote:
> Hi!
> I’ve used something like this to get unique Ids:
> SELECT row_number() OVER (ORDER BY s.omrade_id, s.kod) AS id, …. ORDER BY
> s.omrade_id, s.kod;
> If the ordering isn’t necessary I guess you can skip that.
> https://www.postgresql.org/docs/current/static/functions-window.html
> *Karl-Magnus Jönsson*
> *Från:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För *Árni
> Geirsson
> *Skickat:* den 12 april 2017 11:34
> *Till:* qgis-user at lists.osgeo.org
> *Ämne:* [Qgis-user] Unique IDs in a PostGIS view
> I am trying to create a view that extracts vertices from lines using
> ST_DumpPoints and to get unique IDs I have set up a sequence to generate
> the numbers using nextval(). The query executes normally in the DB Mananger
> and I see the results as a table in the table view. However, when I attempt
> to load the results of the view as a layer in QGIS, I get an error:
> "Database error: ERROR: cannot execute nextval() in a read-only
> transaction". No features are loaded.
> Are there any smart tricks out there to work around this or other means of
> generating the IDs?
> Árni Geirsson
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170412/c9892ecc/attachment.html>
